Ana içeriğe geç
How to Fix a Jammed Mahjong Table
Neye ihtiyacın var
    1. How to Fix a Jammed Mahjong Table, How to Fix a Jammed Mahjong Table: adım 1, 1 resimden 1.
      • Unplug the mahjong table.
      FixBot'a Sor
      Yorum Ekle
    2. How to Fix a Jammed Mahjong Table: adım 2, 1 resimden 1.
      • Remove the outer edge of the mahjong table and set it aside.
      FixBot'a Sor
      Yorum Ekle
    3. How to Fix a Jammed Mahjong Table: adım 3, 2 resimden 1. How to Fix a Jammed Mahjong Table: adım 3, 2 resimden 2.
      • Lift the top frame up, exposing the inside.
      FixBot'a Sor
      Yorum Ekle
    4. How to Fix a Jammed Mahjong Table: adım 4, 3 resimden 1. How to Fix a Jammed Mahjong Table: adım 4, 3 resimden 2. How to Fix a Jammed Mahjong Table: adım 4, 3 resimden 3.
      • Be cautious when putting your hands inside due to sharp parts: gloves and tweezer recommended.
      • Remove the long (green) platform cover of the jammed platform and set it aside to expose the opening of the platform.
      • Carefully remove the foreign object from the opening of the platform.
      FixBot'a Sor
      Yorum Ekle
    5. How to Fix a Jammed Mahjong Table: adım 5, 1 resimden 1.
      • After removing the foreign object, remove the rest of the tiles and set them aside.
      FixBot'a Sor
      Yorum Ekle
    6. How to Fix a Jammed Mahjong Table: adım 6, 2 resimden 1. How to Fix a Jammed Mahjong Table: adım 6, 2 resimden 2.
      • Reassemble all the components and turn on the power.
      FixBot'a Sor
      Yorum Ekle
    7. How to Fix a Jammed Mahjong Table: adım 7, 1 resimden 1.
      • Press the center control panel to expose the center hole.
      • Push all the tiles in the center hole to ensure the machine properly builds the "wall" for play.
      FixBot'a Sor
      Yorum Ekle
Bitiş Çizgisi
2 farklı kişi bu kılavuzu tamamladı.
ShuRen
175 İtibar
1 Kılavuz yazıldı
Ekip
UC Davis, Team 1-4, Whithaus Spring 2024 UC Davis, Team 1-4, Whithaus Spring 2024 üyesi
UCD-WHITHAUS-S24S1G4
3 Üyeler
9 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 34
Son 30 gün: 195
Her zaman: 2,671
