Ana içeriğe geç
How to Fix a Jammed Weiser SmartCode 10 Touchscreen Door Lock
Neye ihtiyacın var
  1. How to Fix a Jammed Weiser SmartCode 10 Touchscreen Door Lock, How to Fix a Jammed Weiser SmartCode 10 Touchscreen Door Lock: adım 1, 2 resimden 1. How to Fix a Jammed Weiser SmartCode 10 Touchscreen Door Lock, How to Fix a Jammed Weiser SmartCode 10 Touchscreen Door Lock: adım 1, 2 resimden 2.
    • Make sure the lock is in the unlock position when you start.
    • Use a Philips #1 screwdriver to remove the two 8 mm screws from the left and right sides of the lock.
  2. How to Fix a Jammed Weiser SmartCode 10 Touchscreen Door Lock: adım 2, 3 resimden 1. How to Fix a Jammed Weiser SmartCode 10 Touchscreen Door Lock: adım 2, 3 resimden 2. How to Fix a Jammed Weiser SmartCode 10 Touchscreen Door Lock: adım 2, 3 resimden 3.
    • Lift the faceplate from the lock.
    • Locate the battery pack stationed at the top of the lock and the programming button at the center of the lock.
  3. How to Fix a Jammed Weiser SmartCode 10 Touchscreen Door Lock: adım 3, 1 resimden 1.
    • Pull the battery pack up and off to remove it from the lock housing.
  4. How to Fix a Jammed Weiser SmartCode 10 Touchscreen Door Lock: adım 4, 2 resimden 1. How to Fix a Jammed Weiser SmartCode 10 Touchscreen Door Lock: adım 4, 2 resimden 2.
    • Re-insert the battery pack while holding down the programming button.
    • Ensure the battery pack is fully inserted by pushing it down.
  5. How to Fix a Jammed Weiser SmartCode 10 Touchscreen Door Lock: adım 5, 3 resimden 1. How to Fix a Jammed Weiser SmartCode 10 Touchscreen Door Lock: adım 5, 3 resimden 2. How to Fix a Jammed Weiser SmartCode 10 Touchscreen Door Lock: adım 5, 3 resimden 3.
    • Release the programming button after the indicator light turns red then green.
    • Repeat steps 3 through 5 if the light does not turn green.
  6. How to Fix a Jammed Weiser SmartCode 10 Touchscreen Door Lock: adım 6, 2 resimden 1. How to Fix a Jammed Weiser SmartCode 10 Touchscreen Door Lock: adım 6, 2 resimden 2.
    • Press the program button again to allow the Smartlock to re-calibrate and reprogram itself.
    • The lock will lock and unlock a few times to calibrate and will remain in the lock position when the calibration is complete.
  7. How to Fix a Jammed Weiser SmartCode 10 Touchscreen Door Lock: adım 7, 3 resimden 1. How to Fix a Jammed Weiser SmartCode 10 Touchscreen Door Lock: adım 7, 3 resimden 2. How to Fix a Jammed Weiser SmartCode 10 Touchscreen Door Lock: adım 7, 3 resimden 3.
    • To reassemble your lock, reseat the faceplate on the lock.
    • Twist the lock switch until it aligns with the bolt mechanism and the faceplate sits flush against the lock.
    • Use the Phillips #1 screwdriver to secure the two 8 mm screws back into place to conclude the fix.
Sonuç
Your lock will not jam anymore!
Bir başkası bu kılavuzu tamamladı.
Manpreet Sahota
145 İtibar
1 Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 10
Son 7 gün: 95
Son 30 gün: 380
Her zaman: 14,833
