Ana içeriğe geç
How to Fix a Leaky Gutter
Neye ihtiyacın var
  1. How to Fix a Leaky Gutter, How to Fix a Leaky Gutter: adım 1, 3 resimden 1. How to Fix a Leaky Gutter, How to Fix a Leaky Gutter: adım 1, 3 resimden 2. How to Fix a Leaky Gutter, How to Fix a Leaky Gutter: adım 1, 3 resimden 3.
    • Clean the area around the leak with a wire bush or garden trowel and a bucket, taking out the leaves and debris placing what you remove in the bucket and flushing the gutters with water using a hose to make sure you have a clean area, as well as rinsing and drying the area thoroughly.
    • Since this requires a ladder, it is better to have another adult nearby just to stay safe!
  2. How to Fix a Leaky Gutter: adım 2, 1 resimden 1.
    • Apply plastic roofing cement to any holes present in the gutters by working it into the hole or crack with a putty knife or trowel.
  3. How to Fix a Leaky Gutter: adım 3, 1 resimden 1.
    • Smooth out the cement by using the putty knife or trowel so that can smooth out any rough edges.
  4. How to Fix a Leaky Gutter: adım 4, 1 resimden 1.
    • Remove any screws or connecting hardware at the joint of any leaking or worn portion of the downspout and then disassemble any leaking or worn portion of the downspout joint.
  5. How to Fix a Leaky Gutter: adım 5, 1 resimden 1.
    • Clean any caulks from around the downspout joints using a stiff wire brush.
  6. How to Fix a Leaky Gutter: adım 6, 1 resimden 1.
    • Apply the silicone caulk to the joint area to seal leaks and reassemble the gutter system.
Sonuç
To reassemble the downsprout: screw back any screws or connecting hardware back into the downsprout.
2 farklı kişi bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 61
Her zaman: 1,845
