Ana içeriğe geç
How to Fix a Loose Connection on a Power Strip
Neye ihtiyacın var
  1. How to Fix a Loose Connection on a Power Strip, How to Fix a Loose Connection on a Power Strip: adım 1, 1 resimden 1.
    • Before you start, make sure you unplug the power strip from the wall! It is very important, as you will get an electric shock if you do not do so.
    • Take out all the plugs on the power strip.
  2. How to Fix a Loose Connection on a Power Strip: adım 2, 2 resimden 1. How to Fix a Loose Connection on a Power Strip: adım 2, 2 resimden 2.
    • Flip over the power strip.
    • Use a Phillips #0 screwdriver to take out the 6 mm screws on the back of the power strip.
  3. How to Fix a Loose Connection on a Power Strip: adım 3, 2 resimden 1. How to Fix a Loose Connection on a Power Strip: adım 3, 2 resimden 2.
    • Separate the outer shell from the power strip.
    • Most of the outer shells can be separated out very easily after the screws are taken out.
  4. How to Fix a Loose Connection on a Power Strip: adım 4, 2 resimden 1. How to Fix a Loose Connection on a Power Strip: adım 4, 2 resimden 2.
    • Locate two pairs of copper sheets for each socket.
  5. How to Fix a Loose Connection on a Power Strip: adım 5, 3 resimden 1. How to Fix a Loose Connection on a Power Strip: adım 5, 3 resimden 2. How to Fix a Loose Connection on a Power Strip: adım 5, 3 resimden 3.
    • Use a screwdriver to push the two copper sheets closer to each other. Do this on all the pairs of copper sheets without a solid connection.
  6. How to Fix a Loose Connection on a Power Strip: adım 6, 2 resimden 1. How to Fix a Loose Connection on a Power Strip: adım 6, 2 resimden 2.
    • Install the outer shell back to the power strip.
    • Put the outer shell on it and press it to install.
  7. How to Fix a Loose Connection on a Power Strip: adım 7, 2 resimden 1. How to Fix a Loose Connection on a Power Strip: adım 7, 2 resimden 2.
    • Flip over the power strip, and then use screwdriver to install all the screws back.
  8. How to Fix a Loose Connection on a Power Strip: adım 8, 1 resimden 1.
    • Plug the power strip into the wall socket, and then plug electric machine to the power strip to test that if the connection of power strip has improved.
Sonuç
You’re all done!
Bir başkası bu kılavuzu tamamladı.
Xike Cao
219 İtibar
1 Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 20
Son 30 gün: 68
Her zaman: 2,251
