Ana içeriğe geç
How to Fix a Loose Connector in an Anivia 1080p Webcam
Neye ihtiyacın var
  1. How to Fix a Loose Connector in an Anivia 1080p Webcam, How to Fix a Loose Connector in an Anivia 1080p Webcam: adım 1, 3 resimden 1. How to Fix a Loose Connector in an Anivia 1080p Webcam, How to Fix a Loose Connector in an Anivia 1080p Webcam: adım 1, 3 resimden 2. How to Fix a Loose Connector in an Anivia 1080p Webcam, How to Fix a Loose Connector in an Anivia 1080p Webcam: adım 1, 3 resimden 3.
    • Pry open the face plate of the webcam using the iFixit opening pick or another safe tool, and set it aside.
  2. How to Fix a Loose Connector in an Anivia 1080p Webcam: adım 2, 3 resimden 1. How to Fix a Loose Connector in an Anivia 1080p Webcam: adım 2, 3 resimden 2. How to Fix a Loose Connector in an Anivia 1080p Webcam: adım 2, 3 resimden 3.
    • Remove the three main screws using a Phillips screwdriver while carefully holding the camera motherboard in place.
  3. How to Fix a Loose Connector in an Anivia 1080p Webcam: adım 3, 3 resimden 1. How to Fix a Loose Connector in an Anivia 1080p Webcam: adım 3, 3 resimden 2. How to Fix a Loose Connector in an Anivia 1080p Webcam: adım 3, 3 resimden 3.
    • Remove the camera and motherboard from the casing carefully.
  4. How to Fix a Loose Connector in an Anivia 1080p Webcam: adım 4, 3 resimden 1. How to Fix a Loose Connector in an Anivia 1080p Webcam: adım 4, 3 resimden 2. How to Fix a Loose Connector in an Anivia 1080p Webcam: adım 4, 3 resimden 3.
    • Detach the cable from the connecter on the motherboard.
    • Pull from the plastic as to not damage any of the wires.
  5. How to Fix a Loose Connector in an Anivia 1080p Webcam: adım 5, 3 resimden 1. How to Fix a Loose Connector in an Anivia 1080p Webcam: adım 5, 3 resimden 2. How to Fix a Loose Connector in an Anivia 1080p Webcam: adım 5, 3 resimden 3.
    • Identify where the connector is loose and solder the piece back into place.
    • Use only as little solder as needed to keep functionality in tact.
    • Caution: The soldering iron is hot and should be handled with care.
  6. How to Fix a Loose Connector in an Anivia 1080p Webcam: adım 6, 2 resimden 1. How to Fix a Loose Connector in an Anivia 1080p Webcam: adım 6, 2 resimden 2.
    • Reattach the cable to the connector.
  7. How to Fix a Loose Connector in an Anivia 1080p Webcam: adım 7, 2 resimden 1. How to Fix a Loose Connector in an Anivia 1080p Webcam: adım 7, 2 resimden 2.
    • Place the motherboard and camera back into the casing.
  8. How to Fix a Loose Connector in an Anivia 1080p Webcam: adım 8, 3 resimden 1. How to Fix a Loose Connector in an Anivia 1080p Webcam: adım 8, 3 resimden 2. How to Fix a Loose Connector in an Anivia 1080p Webcam: adım 8, 3 resimden 3.
    • Screw the camera and motherboard back into place.
  9. How to Fix a Loose Connector in an Anivia 1080p Webcam: adım 9, 3 resimden 1. How to Fix a Loose Connector in an Anivia 1080p Webcam: adım 9, 3 resimden 2. How to Fix a Loose Connector in an Anivia 1080p Webcam: adım 9, 3 resimden 3.
    • Snap the faceplate covering back into place.
Bitiş Çizgisi
Duncan Holloway
169 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 8
Son 30 gün: 36
Her zaman: 846
