Ana içeriğe geç
How to Fix a Loose Turret on a Sony Cyber-shot DSC-F828
Neye ihtiyacın var
  1. How to Fix a Loose Turret on a Sony Cyber-shot DSC-F828, How to Fix a Loose Turret on a Sony Cyber-shot DSC-F828: adım 1, 2 resimden 1. How to Fix a Loose Turret on a Sony Cyber-shot DSC-F828, How to Fix a Loose Turret on a Sony Cyber-shot DSC-F828: adım 1, 2 resimden 2.
    • Slide the button back to open the battery cover.
  2. How to Fix a Loose Turret on a Sony Cyber-shot DSC-F828: adım 2, 2 resimden 1. How to Fix a Loose Turret on a Sony Cyber-shot DSC-F828: adım 2, 2 resimden 2.
    • Pull back on the tab to release the battery.
    • Pull the battery out, then close the lid.
  3. How to Fix a Loose Turret on a Sony Cyber-shot DSC-F828: adım 3, 1 resimden 1.
    • Remove the screw on the back of the turret with a JIS #00 screwdriver.
  4. How to Fix a Loose Turret on a Sony Cyber-shot DSC-F828: adım 4, 2 resimden 1. How to Fix a Loose Turret on a Sony Cyber-shot DSC-F828: adım 4, 2 resimden 2.
    • Remove two screws from each side of the camera (four in total) using a JIS #00 screwdriver.
  5. How to Fix a Loose Turret on a Sony Cyber-shot DSC-F828: adım 5, 1 resimden 1.
    • Remove the screw on the bottom of the turret using a JIS #00 screwdriver.
  6. How to Fix a Loose Turret on a Sony Cyber-shot DSC-F828: adım 6, 1 resimden 1.
    • Carefully pull the face plate off and lay it down.
    • There is a cable attached to the plate that should not be removed.
  7. How to Fix a Loose Turret on a Sony Cyber-shot DSC-F828: adım 7, 2 resimden 1. How to Fix a Loose Turret on a Sony Cyber-shot DSC-F828: adım 7, 2 resimden 2.
    • Tighten the two screws using a JIS #00 screwdriver.
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Bir Yorum
Thanks, I just used this to tighten the pivot on an F828 I got on eBay. Super easy.
photoman12001 - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 12
Son 30 gün: 32
Her zaman: 1,158
