Ana içeriğe geç
How to Fix a Noisy Punching Bag Ceiling Mount
Neye ihtiyacın var
  1. How to Fix a Noisy Punching Bag Ceiling Mount, Punching Bag Snap Hooks: adım 1, 3 resimden 1. How to Fix a Noisy Punching Bag Ceiling Mount, Punching Bag Snap Hooks: adım 1, 3 resimden 2. How to Fix a Noisy Punching Bag Ceiling Mount, Punching Bag Snap Hooks: adım 1, 3 resimden 3.
    • This is how the ceiling bag looks without the adjustments. No flexibility and sturdiness are the causes behind the noise.
    • This is an unsafe attachment of the bag to the ceiling mount. Too much pressure on the ceiling mount can lead to it breaking, therefore making the bag dangerous to its surroundings.
  2. How to Fix a Noisy Punching Bag Ceiling Mount: adım 2, 2 resimden 1. How to Fix a Noisy Punching Bag Ceiling Mount: adım 2, 2 resimden 2.
    • With the help of another individual, remove the punching bag from the ceiling mount.
    • To prevent the punching bag from falling on its surroundings, place it either flat on the ground or against the wall.
  3. How to Fix a Noisy Punching Bag Ceiling Mount: adım 3, 3 resimden 1. How to Fix a Noisy Punching Bag Ceiling Mount: adım 3, 3 resimden 2. How to Fix a Noisy Punching Bag Ceiling Mount: adım 3, 3 resimden 3.
    • Using a wrench or a drive ratchet, remove the hex nut from the hex screw.
    • Hold the hex nut with a plier for better grip (this helps with unscrewing).
    • Remove the hex screw from the ceiling mount.
  4. How to Fix a Noisy Punching Bag Ceiling Mount: adım 4, 3 resimden 1. How to Fix a Noisy Punching Bag Ceiling Mount: adım 4, 3 resimden 2. How to Fix a Noisy Punching Bag Ceiling Mount: adım 4, 3 resimden 3.
    • Tighten the middle hex screw with the help of a drive ratchet.
    • Make sure the top hex nut is as tight as possible.
    • You can hold the TOP hex nut with a plier while tightening the middle hex nut for better results.
  5. How to Fix a Noisy Punching Bag Ceiling Mount: adım 5, 2 resimden 1. How to Fix a Noisy Punching Bag Ceiling Mount: adım 5, 2 resimden 2.
    • Reinsert the hex screw back into the ceiling mount. Place the Swivel Hook inside the hex screw.
    • The Swivel Hook should be attached/connected to the hex screw.
  6. How to Fix a Noisy Punching Bag Ceiling Mount: adım 6, 3 resimden 1. How to Fix a Noisy Punching Bag Ceiling Mount: adım 6, 3 resimden 2. How to Fix a Noisy Punching Bag Ceiling Mount: adım 6, 3 resimden 3.
    • Tighten back the bolt screw onto the hex screw.
    • Using a plier and a drive ratchet, fully tighten the hex screw onto the hex nut.
  7. How to Fix a Noisy Punching Bag Ceiling Mount: adım 7, 3 resimden 1. How to Fix a Noisy Punching Bag Ceiling Mount: adım 7, 3 resimden 2. How to Fix a Noisy Punching Bag Ceiling Mount: adım 7, 3 resimden 3.
    • Attach a Snap Hook to the Spring. Use a snap hook to connect the Spring with the Swivel Hook.
    • Attach the Snap Hook to the Swivel Hook.
    • This is how the Spring should be connected to the Swivel Hook.
  8. How to Fix a Noisy Punching Bag Ceiling Mount: adım 8, 3 resimden 1. How to Fix a Noisy Punching Bag Ceiling Mount: adım 8, 3 resimden 2. How to Fix a Noisy Punching Bag Ceiling Mount: adım 8, 3 resimden 3.
    • Connect the punching bag with Spring. Attach the punching bag snap hook to the Spring.
  9. How to Fix a Noisy Punching Bag Ceiling Mount: adım 9, 1 resimden 1.
    • Make sure the punching bag hangs steadily, and all components are tight.
Sonuç
bilalbutt
169 İtibar
1 Kılavuz yazıldı
Bir Yorum
Tighten any loose screws, bolts, or nuts, and make sure the mount is securely fastened to the ceiling. If the noise persists, try adding some padding between the mount and the ceiling. This can be achieved by using rubber or foam mats, or even by simply placing folded towels between the mount and the ceiling. By taking these steps to fix a noisy punching bag ceiling mount, you can enjoy a more peaceful and productive workout. With the right equipmenta good punching bag and the best starter boxing gloves, you can train safely and effectively, and work towards achieving your fitness and boxing goals.
WesHenry - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 9
Son 7 gün: 33
Son 30 gün: 178
Her zaman: 6,380
