Ana içeriğe geç
How to Fix a Papasan Chair Base
Neye ihtiyacın var
  1. How to Fix a Papasan Chair Base, How to Fix a Papasan Chair Base: adım 1, 2 resimden 1. How to Fix a Papasan Chair Base, How to Fix a Papasan Chair Base: adım 1, 2 resimden 2.
    • Remove and save rattan from broken sections.
  2. How to Fix a Papasan Chair Base: adım 2, 1 resimden 1.
    • Remove old nails from the sections that have separated. Pliers may be helpful for nails that are hard to reach with the claw of a hammer.
  3. How to Fix a Papasan Chair Base: adım 3, 2 resimden 1. How to Fix a Papasan Chair Base: adım 3, 2 resimden 2.
    • Glue the split wood pieces together, clamp, and let them dry.
  4. How to Fix a Papasan Chair Base: adım 4, 1 resimden 1.
    • Nail the thin decorative wood pieces to the larger sections of the frame.
  5. How to Fix a Papasan Chair Base: adım 5, 1 resimden 1.
    • Screw the circular base and upper to the vertical supports that have become disconnected.
    What is the size of the screw?
    Lourdes Diaz - Yanıt
    Or what kind (spec) of screw do I need for this part?
  6. How to Fix a Papasan Chair Base: adım 6, 1 resimden 1.
    • Screw together two ends of the circular part of the frame. Align the screw to be perpendicular to the seam where the two ends connect.
  7. How to Fix a Papasan Chair Base: adım 7, 2 resimden 1. How to Fix a Papasan Chair Base: adım 7, 2 resimden 2.
    • Nail down one side of the rattan and re-wrap it. Finish by nailing down the other end of the rattan to secure it.
Sonuç
Following these steps will restore your papasan chair to working order.
6 farklı kişi bu kılavuzu tamamladı.
3Kılavuz Yorumları
What screw you used? Screw dimensions?
easy peasy…thanks
Katherine Elaine - Yanıt
Were u would u recommend get the wicker to wrap chairs , at???
Thanks in advance!!!
Carrmone Bears - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 38
Son 30 gün: 155
Her zaman: 20,199
