Ana içeriğe geç
How to Fix a Paper Jam From the Rear in a Canon Pixma TR4520
Neye ihtiyacın var
  1. How to Fix a Paper Jam From the Rear in a Canon Pixma TR4520, How to Fix a Paper Jam From the Rear in a Canon Pixma TR4520: adım 1, 1 resimden 1.
    • Press Stop to cancel the print job.
  2. How to Fix a Paper Jam From the Rear in a Canon Pixma TR4520: adım 2, 2 resimden 1. How to Fix a Paper Jam From the Rear in a Canon Pixma TR4520: adım 2, 2 resimden 2.
    • Turn off the printer.
    • Unplug your printer from the power source.
  3. How to Fix a Paper Jam From the Rear in a Canon Pixma TR4520: adım 3, 2 resimden 1. How to Fix a Paper Jam From the Rear in a Canon Pixma TR4520: adım 3, 2 resimden 2.
    • Open the front tray and check for jammed paper.
    • If you don't see any jammed paper, skip to step 5.
  4. How to Fix a Paper Jam From the Rear in a Canon Pixma TR4520: adım 4, 2 resimden 1. How to Fix a Paper Jam From the Rear in a Canon Pixma TR4520: adım 4, 2 resimden 2.
    • Pull the paper out slowly using both of your hands to avoid tearing.
    • If paper tears apart, do not force the paper out. You can remove any remaining paper by accessing the back panel.
    • If you were able to remove all of the jammed paper through the front, there's no need to continue! Simply proceed using your printer as normal.
  5. How to Fix a Paper Jam From the Rear in a Canon Pixma TR4520: adım 5, 3 resimden 1. How to Fix a Paper Jam From the Rear in a Canon Pixma TR4520: adım 5, 3 resimden 2. How to Fix a Paper Jam From the Rear in a Canon Pixma TR4520: adım 5, 3 resimden 3.
    • Lay the printer on its backside to expose the bottom panel.
    • Remove the two screws holding the transport unit cover in place with a Phillips #1 screwdriver.
  6. How to Fix a Paper Jam From the Rear in a Canon Pixma TR4520: adım 6, 2 resimden 1. How to Fix a Paper Jam From the Rear in a Canon Pixma TR4520: adım 6, 2 resimden 2.
    • Lift off the transport unit cover.
    • Be gentle while removing the cover. You don't want to damage it.
  7. How to Fix a Paper Jam From the Rear in a Canon Pixma TR4520: adım 7, 2 resimden 1. How to Fix a Paper Jam From the Rear in a Canon Pixma TR4520: adım 7, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • Remove any remaining paper gently either using your fingers or a pair of tweezers.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Ani Gurtsishvili
235 İtibar
1 Kılavuz yazıldı
Ekip
7 Yorum
can you show the whole bottom without the tray being in the way? I would really appreciate!
Lex - Yanıt
it still has the two lights blinking
kresge - Yanıt
directions did not help, the yellow and ogange till blinks
kresge - Yanıt
it did not work
kresge - Yanıt
Papers stuck it won’t budge I’m underneath and it’s gripped it like a vice! Didn’t work where do we go from here this is horrible!
Leah Campbell - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 11
Son 7 gün: 60
Son 30 gün: 208
Her zaman: 11,943
