Ana içeriğe geç
How to Fix a Rattling Door
Neye ihtiyacın var
  1. How to Fix a Rattling Door, How to Fix a Rattling Door: adım 1, 3 resimden 1. How to Fix a Rattling Door, How to Fix a Rattling Door: adım 1, 3 resimden 2. How to Fix a Rattling Door, How to Fix a Rattling Door: adım 1, 3 resimden 3.
    • Remove the strike plate on the door by unscrewing the screws that attach it to the door frame.
    • The type of screwdriver you need depends on the type of screws that hold your strike plate in your door.
  2. How to Fix a Rattling Door: adım 2, 2 resimden 1. How to Fix a Rattling Door: adım 2, 2 resimden 2.
    • Take the strike plate and put it in your hand. Using the pliers in your other hand, bend the metal tab toward the flat side of the strike plate.
  3. How to Fix a Rattling Door: adım 3, 2 resimden 1. How to Fix a Rattling Door: adım 3, 2 resimden 2.
    • Place the strike plate back on the door frame and tighten the screws.
Sonuç
Close your door and shake it back and forth to see if it is still loose. Repeat the guide steps as necessary.
2 farklı kişi bu kılavuzu tamamladı.
Sara Novell
209 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 30-4, Green Spring 2015 Cal Poly, Team 30-4, Green Spring 2015 üyesi
CPSU-GREEN-S15S30G4
5 Üyeler
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 13
Son 30 gün: 40
Her zaman: 40,084
