Ana içeriğe geç
How to Fix a Razer Naga Trinity Click Button
Neye ihtiyacın var
  1. How to Fix a Razer Naga Trinity Click Button, How to Fix a Razer Naga Trinity Click Button: adım 1, 3 resimden 1. How to Fix a Razer Naga Trinity Click Button, How to Fix a Razer Naga Trinity Click Button: adım 1, 3 resimden 2. How to Fix a Razer Naga Trinity Click Button, How to Fix a Razer Naga Trinity Click Button: adım 1, 3 resimden 3.
    • Remove the three pads from the bottom of the mouse.
    • Remove the four screws beneath the pads using a JIS #1 screwdriver.
  2. How to Fix a Razer Naga Trinity Click Button: adım 2, 2 resimden 1. How to Fix a Razer Naga Trinity Click Button: adım 2, 2 resimden 2.
    • Press the top of mouse and pull back to disconnect the mouse shell.
    • Pull out the cord that connects the RGB button.
  3. How to Fix a Razer Naga Trinity Click Button: adım 3, 2 resimden 1. How to Fix a Razer Naga Trinity Click Button: adım 3, 2 resimden 2.
    • Remove the right shell.
    • Disconnect the cable connecting the left shell to the mouse.
    • Remove the left shell.
  4. How to Fix a Razer Naga Trinity Click Button: adım 4, 1 resimden 1.
    • Use a safety pin to unlatch the clicker buttons.
  5. How to Fix a Razer Naga Trinity Click Button: adım 5, 2 resimden 1. How to Fix a Razer Naga Trinity Click Button: adım 5, 2 resimden 2.
    • Insert the open safety pin to lift one side latch slightly.
    • Do not open the whole part.
    • Repeat for the other side.
  6. How to Fix a Razer Naga Trinity Click Button: adım 6, 3 resimden 1. How to Fix a Razer Naga Trinity Click Button: adım 6, 3 resimden 2. How to Fix a Razer Naga Trinity Click Button: adım 6, 3 resimden 3.
    • Remove the clicker and white pin.
    • Gently press the middle part of the copper sheet until it unhooks itself.
    • Pull the bended part of the copper sheet back.
  7. How to Fix a Razer Naga Trinity Click Button: adım 7, 1 resimden 1.
    • Reassemble the copper sheet with the white pin seated properly.
    • Push the spring down into its place using a spudger.
    • You will hear a click sound if you successfully assemble it.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Haoran Ke
283 İtibar
1 Kılavuz yazıldı
Ekip
1Rehber Yorum
On the latest version of the mouse, the clicker button can no longer be opened...
Jérémie PLAYOUT - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 17
Son 7 gün: 64
Son 30 gün: 275
Her zaman: 11,710
