Ana içeriğe geç
How to Fix a Ripped Necktie Seam
Neye ihtiyacın var
  1. How to Fix a Ripped Necktie Seam, Ripped Seam: adım 1, 1 resimden 1.
    • Iron the area of the necktie that is ripped.
    • Ironing the necktie allows for clean lines and no wrinkles in the fabric.
    • When ironing, be careful not to burn yourself.
  2. How to Fix a Ripped Necktie Seam: adım 2, 1 resimden 1.
    • Position your tie with ripped seam facing up.
  3. How to Fix a Ripped Necktie Seam: adım 3, 1 resimden 1.
    • Gather your thread and scissors.
    • Cut to desired length.
    • Make sure your thread matches the color of your tie.
  4. How to Fix a Ripped Necktie Seam: adım 4, 2 resimden 1. How to Fix a Ripped Necktie Seam: adım 4, 2 resimden 2.
    • Gather your cut thread and needle.
    • Loop your thread through the eye of the needle.
    • Pull the thread until it is even on both ends.
    • Be careful of sharp needle.
  5. How to Fix a Ripped Necktie Seam: adım 5, 1 resimden 1.
    • Tie the end of the thread with a knot.
  6. How to Fix a Ripped Necktie Seam: adım 6, 3 resimden 1. How to Fix a Ripped Necktie Seam: adım 6, 3 resimden 2. How to Fix a Ripped Necktie Seam: adım 6, 3 resimden 3.
    • Poke your needle from the inside of the tie.
    • Pull the thread all the way through until it reaches the tied knot.
    • Leave about 1/4 inches from the original hole.
    • Poke your needle from the outside of the tie and pull thread until knot.
    • Be careful of sharp needle going in and out of fabric
  7. How to Fix a Ripped Necktie Seam: adım 7, 3 resimden 1. How to Fix a Ripped Necktie Seam: adım 7, 3 resimden 2. How to Fix a Ripped Necktie Seam: adım 7, 3 resimden 3.
    • Repeat the sewing pattern until you reach the end.
    • Make sure your final thread is through the inside of tie.
  8. How to Fix a Ripped Necktie Seam: adım 8, 2 resimden 1. How to Fix a Ripped Necktie Seam: adım 8, 2 resimden 2.
    • Once the entire seam has been sewn, create a loop with the thread.
    • To tie a knot, bring your needle through the loop and pull.
    • Repeat the knot 2-3 more times.
    • Make sure the knot is flat against the fabric.
  9. How to Fix a Ripped Necktie Seam: adım 9, 2 resimden 1. How to Fix a Ripped Necktie Seam: adım 9, 2 resimden 2.
    • Cut off any excess thread.
    • Do not cut too close to knot or it may unravel.
  10. How to Fix a Ripped Necktie Seam: adım 10, 1 resimden 1.
    • (Optional) Iron over seam for better results.
Sonuç
Beverly Fan
181 İtibar
1 Kılavuz yazıldı
Ekip
UC Davis, Team 2-4, Andersen Winter 2023 UC Davis, Team 2-4, Andersen Winter 2023 üyesi
UCD-ANDERSEN-W23S2G4
3 Üyeler
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 23
Son 30 gün: 68
Her zaman: 905
