Ana içeriğe geç
How to Fix a Ripped Stuffed Animal
Arşivlenmiş Kılavuz
Bu kılavuz sadece arşivsel amaçlarla muhafaza edilmiştir. Onarımınızı gerçekleştirmek için kılavuzun güncel halini kullanın.
Neye ihtiyacın var
  1. How to Fix a Ripped Stuffed Animal, How to Fix a Ripped Stuffed Animal: adım 1, 3 resimden 1. How to Fix a Ripped Stuffed Animal, How to Fix a Ripped Stuffed Animal: adım 1, 3 resimden 2. How to Fix a Ripped Stuffed Animal, How to Fix a Ripped Stuffed Animal: adım 1, 3 resimden 3.
    • Use Polyester Fiberfill stuffing to fill the stuffed bear via rip. Add more stuffing for a firmer toy.
    • Do not overfill the toy, or it may rip again.
  2. How to Fix a Ripped Stuffed Animal: adım 2, 1 resimden 1.
    • Insert a thread through the eye of the needle (the hole) and tie it tightly to the needle.
  3. How to Fix a Ripped Stuffed Animal: adım 3, 1 resimden 1.
    • Make a knot at the loose end of the thread.
    • This is so that the thread doesn't slip through the cloth while sewing up the bear.
  4. How to Fix a Ripped Stuffed Animal: adım 4, 3 resimden 1. How to Fix a Ripped Stuffed Animal: adım 4, 3 resimden 2. How to Fix a Ripped Stuffed Animal: adım 4, 3 resimden 3.
    • Push needle through the end of the rip.
    • Continue along the seam, putting the needle through both sides of the rip to create a stitch.
  5. How to Fix a Ripped Stuffed Animal: adım 5, 2 resimden 1. How to Fix a Ripped Stuffed Animal: adım 5, 2 resimden 2.
    • After the rip is sewn shut, tie the end of the thread by creating a knot
    • Create the knot by wrapping the thread around the needle several times Then pull the thread through to secure the knot at the base.
    • Once is enough, but for more security, you can repeat this step twice.
  6. How to Fix a Ripped Stuffed Animal: adım 6, 3 resimden 1. How to Fix a Ripped Stuffed Animal: adım 6, 3 resimden 2. How to Fix a Ripped Stuffed Animal: adım 6, 3 resimden 3.
    • Cut any excess thread and you're done!
    • Enjoy your repaired stuffed bear!
Sonuç
Megan Nash
108 İtibar
1 Kılavuz yazıldı
Ekip
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 29
Her zaman: 246
