Ana içeriğe geç
How to Fix a Skewed Wheel on a Children's Kick Scooter
Neye ihtiyacın var
  1. How to Fix a Skewed Wheel on a Children's Kick Scooter, How to Fix a Skewed Wheel on a Children's Kick Scooter: adım 1, 3 resimden 1. How to Fix a Skewed Wheel on a Children's Kick Scooter, How to Fix a Skewed Wheel on a Children's Kick Scooter: adım 1, 3 resimden 2. How to Fix a Skewed Wheel on a Children's Kick Scooter, How to Fix a Skewed Wheel on a Children's Kick Scooter: adım 1, 3 resimden 3.
    • Remove the two bottom 16 mm pan head screws using a Phillips #1 screwdriver.
  2. How to Fix a Skewed Wheel on a Children's Kick Scooter: adım 2, 3 resimden 1. How to Fix a Skewed Wheel on a Children's Kick Scooter: adım 2, 3 resimden 2. How to Fix a Skewed Wheel on a Children's Kick Scooter: adım 2, 3 resimden 3.
    • Remove the two 12 mm button head screws on top using a 4 mm Allen wrench.
  3. How to Fix a Skewed Wheel on a Children's Kick Scooter: adım 3, 3 resimden 1. How to Fix a Skewed Wheel on a Children's Kick Scooter: adım 3, 3 resimden 2. How to Fix a Skewed Wheel on a Children's Kick Scooter: adım 3, 3 resimden 3.
    • Remove the plastic case from the base of the scooter.
  4. How to Fix a Skewed Wheel on a Children's Kick Scooter: adım 4, 3 resimden 1. How to Fix a Skewed Wheel on a Children's Kick Scooter: adım 4, 3 resimden 2. How to Fix a Skewed Wheel on a Children's Kick Scooter: adım 4, 3 resimden 3.
    • Carefully pull the sides of the wheels up and remove them from the spring.
  5. How to Fix a Skewed Wheel on a Children's Kick Scooter: adım 5, 3 resimden 1. How to Fix a Skewed Wheel on a Children's Kick Scooter: adım 5, 3 resimden 2. How to Fix a Skewed Wheel on a Children's Kick Scooter: adım 5, 3 resimden 3.
    • Grab the spring with combination pliers and bend it into a straight position.
    • Don't bend the spring too much as it could snap and replacement would be needed.
  6. How to Fix a Skewed Wheel on a Children's Kick Scooter: adım 6, 3 resimden 1. How to Fix a Skewed Wheel on a Children's Kick Scooter: adım 6, 3 resimden 2. How to Fix a Skewed Wheel on a Children's Kick Scooter: adım 6, 3 resimden 3.
    • Insert the spring into the center section of the wheels.
    • Slide the two rings on the sides of the wheels into the two rods.
  7. How to Fix a Skewed Wheel on a Children's Kick Scooter: adım 7, 3 resimden 1. How to Fix a Skewed Wheel on a Children's Kick Scooter: adım 7, 3 resimden 2. How to Fix a Skewed Wheel on a Children's Kick Scooter: adım 7, 3 resimden 3.
    • Insert the plastic case back into its original position.
  8. How to Fix a Skewed Wheel on a Children's Kick Scooter: adım 8, 3 resimden 1. How to Fix a Skewed Wheel on a Children's Kick Scooter: adım 8, 3 resimden 2. How to Fix a Skewed Wheel on a Children's Kick Scooter: adım 8, 3 resimden 3.
    • Insert and tighten the two 12 mm button head screws on top using a 4 mm Allen wrench.
  9. How to Fix a Skewed Wheel on a Children's Kick Scooter: adım 9, 3 resimden 1. How to Fix a Skewed Wheel on a Children's Kick Scooter: adım 9, 3 resimden 2. How to Fix a Skewed Wheel on a Children's Kick Scooter: adım 9, 3 resimden 3.
    • Replace the two bottom 16 mm pan head screws using a Phillips #1 screwdriver.
Bitiş Çizgisi
Amir Issagali
169 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 33
Her zaman: 1,449
