Ana içeriğe geç
How to Fix a Slipping Violin Peg
Neye ihtiyacın var
  1. How to Fix a Slipping Violin Peg, How to Fix a Slipping Violin Peg: adım 1, 3 resimden 1. How to Fix a Slipping Violin Peg, How to Fix a Slipping Violin Peg: adım 1, 3 resimden 2. How to Fix a Slipping Violin Peg, How to Fix a Slipping Violin Peg: adım 1, 3 resimden 3.
    • Completely unwind the string affected by the loose peg.
    • Turn the peg clockwise for strings G and D and counterclockwise for strings A and E.
  2. How to Fix a Slipping Violin Peg: adım 2, 1 resimden 1.
    • Slide the peg out towards you to remove it from the pegbox.
    • The pegbox contains the holes that the pegs go into.
  3. How to Fix a Slipping Violin Peg: adım 3, 2 resimden 1. How to Fix a Slipping Violin Peg: adım 3, 2 resimden 2.
    • Locate the points on the peg that come into contact with the pegbox.
    • Rub the peg compound all the way around the peg on the points that contact the pegbox.
  4. How to Fix a Slipping Violin Peg: adım 4, 3 resimden 1. How to Fix a Slipping Violin Peg: adım 4, 3 resimden 2. How to Fix a Slipping Violin Peg: adım 4, 3 resimden 3.
    • Reinsert the peg by pushing inwards.
    • Turn the peg counterclockwise or clockwise to evenly distribute the compound.
  5. How to Fix a Slipping Violin Peg: adım 5, 2 resimden 1. How to Fix a Slipping Violin Peg: adım 5, 2 resimden 2.
    • Wipe away the excess compound that is outside of the pegbox with a cloth or paper towel.
  6. How to Fix a Slipping Violin Peg: adım 6, 3 resimden 1. How to Fix a Slipping Violin Peg: adım 6, 3 resimden 2. How to Fix a Slipping Violin Peg: adım 6, 3 resimden 3.
    • Locate the hole on the peg and insert the string through it.
    • Tightly angle the string away from the peg head with one hand, while turning the peg toward the scroll with the other hand.
    • The scroll is the woodcarving at the top of the violin.
    • After one or two turns, angle the string toward the peg head (vertical alignment).
  7. How to Fix a Slipping Violin Peg: adım 7, 2 resimden 1. How to Fix a Slipping Violin Peg: adım 7, 2 resimden 2.
    • Tune the string.
    • For strings A and E, tightly turn the peg clockwise, and for strings G and D, turn the peg counterclockwise.
Sonuç
To reassemble your device, follow these instructions in reverse order. Be advised that steps 5 and 7 are optional.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 8
Her zaman: 187
