Ana içeriğe geç
How to Fix a Small Hole in a Sock
Neye ihtiyacın var
  1. How to Fix a Small Hole in a Sock, How to Fix a Small Hole in a Sock: adım 1, 3 resimden 1. How to Fix a Small Hole in a Sock, How to Fix a Small Hole in a Sock: adım 1, 3 resimden 2. How to Fix a Small Hole in a Sock, How to Fix a Small Hole in a Sock: adım 1, 3 resimden 3.
    • Place one end of your thread through the hole of the needle.
    • Wet the end of your thread to make it easier to go through the hole.
    • Pull your thread all the way through and match the ends of the thread together.
    • Tie a knot with the ends of your thread.
    • The needle is sharp. Handle it carefully to prevent poking your fingers or hand.
  2. How to Fix a Small Hole in a Sock: adım 2, 2 resimden 1. How to Fix a Small Hole in a Sock: adım 2, 2 resimden 2.
    • Insert your tennis ball into the sock until it is lined up with the hole in your sock.
  3. How to Fix a Small Hole in a Sock: adım 3, 3 resimden 1. How to Fix a Small Hole in a Sock: adım 3, 3 resimden 2. How to Fix a Small Hole in a Sock: adım 3, 3 resimden 3.
    • Insert your needle into the inside of the sock at the edge of the hole no more than half a centimeter away from the edge.
    • Pull the needle all the way through.
    • If the tail of your thread is too long, trim the excess.
  4. How to Fix a Small Hole in a Sock: adım 4, 1 resimden 1.
    • Insert your needle next to and below where the first insert was.
    • Pull your needle all the way through to create your first stitch.
  5. How to Fix a Small Hole in a Sock: adım 5, 2 resimden 1. How to Fix a Small Hole in a Sock: adım 5, 2 resimden 2.
    • Insert your needle in the opposite side of the hole and pull to create another stitch.
    • Repeat this step, crisscrossing your stitches until you reach the end of the hole.
    • Keep your stitches loose. You will tighten them at the end.
  6. How to Fix a Small Hole in a Sock: adım 6, 3 resimden 1. How to Fix a Small Hole in a Sock: adım 6, 3 resimden 2. How to Fix a Small Hole in a Sock: adım 6, 3 resimden 3.
    • Once you reach the end of the hole, carefully pull on your thread to tighten the stitches together.
  7. How to Fix a Small Hole in a Sock: adım 7, 2 resimden 1. How to Fix a Small Hole in a Sock: adım 7, 2 resimden 2.
    • To close off the stitch, insert your needle back under all of your stitches and pull out your needle at the top of the repair.
    • Pull your needle through, but not all the way, to create a small loop.
  8. How to Fix a Small Hole in a Sock: adım 8, 2 resimden 1. How to Fix a Small Hole in a Sock: adım 8, 2 resimden 2.
    • Insert the needle through the small loop.
    • Pull your needle until the loop disappears.
  9. How to Fix a Small Hole in a Sock: adım 9, 2 resimden 1. How to Fix a Small Hole in a Sock: adım 9, 2 resimden 2.
    • To create a final stitch, insert your needle back under all of your stitches.
    • Pull the thread all the way through.
  10. How to Fix a Small Hole in a Sock: adım 10, 3 resimden 1. How to Fix a Small Hole in a Sock: adım 10, 3 resimden 2. How to Fix a Small Hole in a Sock: adım 10, 3 resimden 3.
    • Trim off the excess thread.
    • Remove the tennis ball from your sock.
Bitiş Çizgisi
3 farklı kişi bu kılavuzu tamamladı.
Yuchen Xu
223 İtibar
1 Kılavuz yazıldı
Ekip
UC Davis, Team 3-2, Andersen Winter 2023 UC Davis, Team 3-2, Andersen Winter 2023 üyesi
UCD-ANDERSEN-W23S3G2
3 Üyeler
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 12
Son 30 gün: 66
Her zaman: 1,128
