Ana içeriğe geç
How to Fix a Squeaky Bed Frame
Neye ihtiyacın var
  1. How to Fix a Squeaky Bed Frame, How to Fix a Squeaky Bed Frame: adım 1, 1 resimden 1.
    • Remove anything that is on the bed frame.
  2. How to Fix a Squeaky Bed Frame: adım 2, 1 resimden 1.
    • Shake the bed frame to pinpoint the area of noise.
  3. How to Fix a Squeaky Bed Frame: adım 3, 1 resimden 1.
    • Identify which type of screw the bedframe uses in the given area.
    • You will need to make use of the corresponding screwdriver throughout the guide.
    • Typically, the bed frame will use the same type of screws throughout.
  4. How to Fix a Squeaky Bed Frame: adım 4, 1 resimden 1.
    • Ensure the components of the bed frame are aligned.
    • Identify gaps between parts of the frame.
    • Tighten the screws where gaps are present
    • Sometimes mismatched components cause squeakiness.
  5. How to Fix a Squeaky Bed Frame: adım 5, 1 resimden 1.
    • Tighten the screws within the area of noise.
    • It is recommended to retighten all the screws to avoid any future squeakiness but it is not required.
  6. How to Fix a Squeaky Bed Frame: adım 6, 1 resimden 1.
    • Spray WD-40 into all the contact points of the bed frame.
    • This includes screws and intersections of the frame.
    • Be careful of the spray around children and your eyes.
  7. How to Fix a Squeaky Bed Frame: adım 7, 1 resimden 1.
    • This is an alternative for the previous step.
    • If WD-40 is not available, using a q-tip dipped in a vegetable oil (or a comparable oil that is available) can be used to lubricate the contact points.
Sonuç
Reassemble the bed to your liking.
Bir başkası bu kılavuzu tamamladı.
Jennifer Nguyen
160 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 14
Son 30 gün: 72
Her zaman: 1,085
