Ana içeriğe geç
How to Fix a Squeaky Bed Frame
Neye ihtiyacın var
    1. How to Fix a Squeaky Bed Frame, How to Fix a Squeaky Bed Frame: adım 1, 1 resimden 1.
      • Remove anything that is on the bed frame.
      FixBot'a Sor
      Yorum Ekle
    2. How to Fix a Squeaky Bed Frame: adım 2, 1 resimden 1.
      • Shake the bed frame to pinpoint the area of noise.
      FixBot'a Sor
      Yorum Ekle
    3. How to Fix a Squeaky Bed Frame: adım 3, 1 resimden 1.
      • Identify which type of screw the bedframe uses in the given area.
      • You will need to make use of the corresponding screwdriver throughout the guide.
      • Typically, the bed frame will use the same type of screws throughout.
      FixBot'a Sor
      Yorum Ekle
    4. How to Fix a Squeaky Bed Frame: adım 4, 1 resimden 1.
      • Ensure the components of the bed frame are aligned.
      • Identify gaps between parts of the frame.
      • Tighten the screws where gaps are present
      • Sometimes mismatched components cause squeakiness.
      FixBot'a Sor
      Yorum Ekle
    5. How to Fix a Squeaky Bed Frame: adım 5, 1 resimden 1.
      • Tighten the screws within the area of noise.
      • It is recommended to retighten all the screws to avoid any future squeakiness but it is not required.
      FixBot'a Sor
      Yorum Ekle
    6. How to Fix a Squeaky Bed Frame: adım 6, 1 resimden 1.
      • Spray WD-40 into all the contact points of the bed frame.
      • This includes screws and intersections of the frame.
      • Be careful of the spray around children and your eyes.
      FixBot'a Sor
      Yorum Ekle
    7. How to Fix a Squeaky Bed Frame: adım 7, 1 resimden 1.
      • This is an alternative for the previous step.
      • If WD-40 is not available, using a q-tip dipped in a vegetable oil (or a comparable oil that is available) can be used to lubricate the contact points.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Reassemble the bed to your liking.
Bir başkası bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 18
Son 30 gün: 98
Her zaman: 3,755
