Ana içeriğe geç
How to Fix a Squeaky Door Hinge
Neye ihtiyacın var
  1. How to Fix a Squeaky Door Hinge, How to Fix a Squeaky Door Hinge: adım 1, 1 resimden 1.
    • Insert the end of the flathead screwdriver into the crease between the top of the pin and the hinge.
  2. How to Fix a Squeaky Door Hinge: adım 2, 1 resimden 1.
    • Take the hammer and hit the handle end of the screwdriver until the pin can be pulled out. This may take a while depending on the door.
  3. How to Fix a Squeaky Door Hinge: adım 3, 1 resimden 1.
    • Place the pin in a bowl of mineral oil (or other household lubricant) and let it rest.
  4. How to Fix a Squeaky Door Hinge: adım 4, 1 resimden 1.
    • Use a brush to apply oil to the empty hinge.
  5. How to Fix a Squeaky Door Hinge: adım 5, 1 resimden 1.
    • Take the pin from the bowl and reinsert it into the door hinge, using a hammer if necessary.
    • Open and close the door a few times. This will help the oil to seep into the cracks of the hinge.
  6. How to Fix a Squeaky Door Hinge: adım 7, 1 resimden 1.
    • Use a towel to catch any drips of oil and to wipe off the hinge.
Sonuç
The door should now be quite silent when opening and closing. Thank you for reading.
3 farklı kişi bu kılavuzu tamamladı.
Jake Herson
219 İtibar
1 Kılavuz yazıldı
Ekip
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 12
Son 7 gün: 85
Son 30 gün: 269
Her zaman: 7,035
