Ana içeriğe geç
How to Fix a Sticking Deadbolt
Neye ihtiyacın var
  1. How to Fix a Sticking Deadbolt, How to Fix a Sticking Deadbolt: adım 1, 2 resimden 1. How to Fix a Sticking Deadbolt, How to Fix a Sticking Deadbolt: adım 1, 2 resimden 2.
    • Use a Phillips screwdriver to remove both of the ¾-inch screws from the strike plate.
  2. How to Fix a Sticking Deadbolt: adım 2, 2 resimden 1. How to Fix a Sticking Deadbolt: adım 2, 2 resimden 2.
    • Remove both of the 2.5 inch mounting screws from the lock cylinder.
  3. How to Fix a Sticking Deadbolt: adım 3, 1 resimden 1.
    • After all four screws have been taken out, slide the latch of the deadbolt out of the door frame.
  4. How to Fix a Sticking Deadbolt: adım 4, 2 resimden 1. How to Fix a Sticking Deadbolt: adım 4, 2 resimden 2.
    • Spray GumOut parts cleaner at an angle into the latch of the deadbolt.
    • Use a rag to clean and dry off latch.
    • We suggest using GumOut cleaning solutions, which is available at most home improvement stores.
  5. How to Fix a Sticking Deadbolt: adım 5, 1 resimden 1.
    • Spray GumOut parts cleaner into the key cylinder to lubricate chamber.
  6. How to Fix a Sticking Deadbolt: adım 6, 2 resimden 1. How to Fix a Sticking Deadbolt: adım 6, 2 resimden 2.
    • Insert dry powdered graphite into the key cylinder of the deadbolt.
    • Place the key into the cylinder to lubricate and clean the chamber.
    • If it is difficult to turn the key, then apply more dry powdered graphite into the cylinder.
  7. How to Fix a Sticking Deadbolt: adım 7, 2 resimden 1. How to Fix a Sticking Deadbolt: adım 7, 2 resimden 2.
    • Apply the dry powdered graphite to the latch of the deadbolt.
    • Use a rag to remove excess dry powdered graphite from the latch.
  8. How to Fix a Sticking Deadbolt: adım 8, 1 resimden 1.
    • Slide the latch of the deadbolt back into the door frame.
  9. How to Fix a Sticking Deadbolt: adım 9, 3 resimden 1. How to Fix a Sticking Deadbolt: adım 9, 3 resimden 2. How to Fix a Sticking Deadbolt: adım 9, 3 resimden 3.
    • Take the lock cylinder and the 2.5 inch mounting screws and insert them through the latch of the deadbolt.
    • Then mount the key cylinder on the screws.
    • Use a Phillips screwdriver to tighten the 2.5 inch mounting screws and secure the deadbolt to the frame.
    • The cylinder should be mounted on the outside of the doorframe.
  10. How to Fix a Sticking Deadbolt: adım 10, 1 resimden 1.
    • Use a Phillips screwdriver to screw in both of the ¾-inch screws back into the strike plate.
Sonuç
After following this fast fix guide, the sticking deadbolt should be fixed.
5 farklı kişi bu kılavuzu tamamladı.
Elizabeth Nesler
214 İtibar
1 Kılavuz yazıldı
Ekip
Texas Tech, Team 22-5, Rauch Spring 2016 Texas Tech, Team 22-5, Rauch Spring 2016 üyesi
TTU-RAUCH-S16S22G5
3 Üyeler
1 Kılavuz yazıldı
Bir Yorum
GumOut Cleaner seems to be initially intended for Brakes and other auto parts. Is that the product you intend?
dan - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 29
Son 30 gün: 134
Her zaman: 39,120
