Ana içeriğe geç
How to Fix a Sticking Kitchen Drawer
Neye ihtiyacın var
  1. How to Fix a Sticking Kitchen Drawer, How to Fix a Sticking Kitchen Drawer: adım 1, 1 resimden 1.
    • Empty the drawer so nothing gets lost or in the way.
  2. How to Fix a Sticking Kitchen Drawer: adım 2, 2 resimden 1. How to Fix a Sticking Kitchen Drawer: adım 2, 2 resimden 2.
    • Remove the drawer. Pull straight out until it locks, then lift up at 30 degrees to disconnect the wheel track from the drawer.
    • This particular drawer has a press-down latch that releases the drawer.
  3. How to Fix a Sticking Kitchen Drawer: adım 3, 1 resimden 1.
    • Remove the slide tracks from the cabinet by unscrewing all screws and then detatching.
    • Keep all of the screws together.
  4. How to Fix a Sticking Kitchen Drawer: adım 4, 1 resimden 1.
    • Now that the slides are removed, diagnose whether they are broken or just need lubrication. If they are broken, replace with a new set.
    • If buying a new slide/wheel, make sure it is the same dimensions.
  5. How to Fix a Sticking Kitchen Drawer: adım 5, 2 resimden 1. How to Fix a Sticking Kitchen Drawer: adım 5, 2 resimden 2.
    • Make sure the track is straight by measuring the height of the screw holes. If the front and back screw holes are more than a half inch apart, see guide for drilling new holes.
    • This only works if the height of the drawer doesn't change.
  6. How to Fix a Sticking Kitchen Drawer: adım 6, 1 resimden 1.
    • Make sure the height of the wheel tracks matches up with the height of the guide tracks by measuring down from a shared point between the drawer and cabinet.
  7. How to Fix a Sticking Kitchen Drawer: adım 7, 1 resimden 1.
    • Lubricate the tracks/wheel by spraying directly with lubricant.
    • Recommended: WD-40.
  8. How to Fix a Sticking Kitchen Drawer: adım 8, 1 resimden 1.
    • Re-attach the wheel tracks with a screwdriver and screws.
  9. How to Fix a Sticking Kitchen Drawer: adım 9, 2 resimden 1. How to Fix a Sticking Kitchen Drawer: adım 9, 2 resimden 2.
    • Insert drawer in the same way it was taken out and then test to make sure it works.
    • The drawer should now slide along the rollers without any problems. If this is the case, you're all done!
Bitiş Çizgisi
9 farklı kişi bu kılavuzu tamamladı.
Kevin Jervis
311 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 24-4, Green Winter 2015 Cal Poly, Team 24-4, Green Winter 2015 üyesi
CPSU-GREEN-W15S24G4
4 Üyeler
4 adet Kılavuz yazıldı
6Kılavuz Yorumları
What about wooden drawers, ie without metal runners, as used for millions of years (approx.)!
The kind littered all over my home, being an old man as I am. Or don`t you know (he he!)
Andrew MacArthur - Yanıt
For wooden drawers without metal runners, I would rub the sliding parts with some soap. The glycerin with help with the friction. Good luck!
Bill -
I don't think that WD40 is a good idea for long term lubrication. It surely cleans the tracks and the rollers but it evaporates quickly. I would suggest cleaning rollers with WD40, then wipe out any WD40 remains with a kitchen paper towel and finally spray some white grease or general light oil lubricant such as the one for sowing machines.
Bill - Yanıt
A tip from a cabinet maker is to lubricate wooden drawer runners with an ordinary candle. The wax will remain slippery for years!
trevorjdowling - Yanıt
For wooden drawers the best way to fix is to rub the sliding parts with candlewax or parrafine. Your drawers will slide like if you were on ice.
Pieter van Ham - Yanıt
Thanks for great guide! Fixing a Sticking Kitchen Drawer can be a Common Kitchen Layout Mistakes. Therefore, We should choose high quality, innovative fixings to create long lasting functional kitchen drawers. From ball bearing and soft close drawer runners to aesthetically pleasing drawer handles, I recommend the essential drawer fixings at SCF Hardware for the professional drawer manufacturer.
alice Gray - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 35
Her zaman: 9,715
