Ana içeriğe geç
How to Fix a Stretched or Loose Canvas
Neye ihtiyacın var
  1. How to Fix a Stretched or Loose Canvas, How to Fix a Stretched or Loose Canvas: adım 1, 2 resimden 1. How to Fix a Stretched or Loose Canvas, How to Fix a Stretched or Loose Canvas: adım 1, 2 resimden 2.
    • Fill a spray bottle with water at room temperature.
    • In case that you do not have a spray bottle you can use a dishcloth and moisten it.
  2. How to Fix a Stretched or Loose Canvas: adım 2, 3 resimden 1. How to Fix a Stretched or Loose Canvas: adım 2, 3 resimden 2. How to Fix a Stretched or Loose Canvas: adım 2, 3 resimden 3.
    • Close the spray bottle tightly.
    • Turn the nozzle to spray.
  3. How to Fix a Stretched or Loose Canvas: adım 3, 2 resimden 1. How to Fix a Stretched or Loose Canvas: adım 3, 2 resimden 2.
    • Put a towel on a flat surface and lay the canvas face down on the towel.
  4. How to Fix a Stretched or Loose Canvas: adım 4, 3 resimden 1. How to Fix a Stretched or Loose Canvas: adım 4, 3 resimden 2. How to Fix a Stretched or Loose Canvas: adım 4, 3 resimden 3.
    • Carefully wet the entire backside of the canvas with the spray, or press water onto the canvas with the dishcloth.
    • Only spray until it is damp. Do not soak the canvas.
    • It does not matter if the canvas is new, old, has unfinished artwork or it is completed.
  5. How to Fix a Stretched or Loose Canvas: adım 5, 2 resimden 1. How to Fix a Stretched or Loose Canvas: adım 5, 2 resimden 2.
    • Turn on the dryer so warm air comes out.
  6. How to Fix a Stretched or Loose Canvas: adım 6, 3 resimden 1. How to Fix a Stretched or Loose Canvas: adım 6, 3 resimden 2. How to Fix a Stretched or Loose Canvas: adım 6, 3 resimden 3.
    • Blow dry the canvas with a hair dryer on warm until it's completely dry.
    • Keep the hair dryer at least 3 to 5 inches away from the canvas.
    • Do not place the hair dryer directly on the canvas. The heat from the hair dryer can burn the canvas.
  7. How to Fix a Stretched or Loose Canvas: adım 7, 2 resimden 1. How to Fix a Stretched or Loose Canvas: adım 7, 2 resimden 2.
    • Flip the canvas over and check that it is to your liking.
    • Flip the canvas again and double check.
    • Repeat the process again if the canvas is not completely fixed.
Sonuç
If it does not work, you should follow another guide where plaster is used in the canvas.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 30
Son 30 gün: 105
Her zaman: 1,539
