Ana içeriğe geç
How to Fix a Stretched or Loose Canvas
Neye ihtiyacın var
  1. How to Fix a Stretched or Loose Canvas, How to Fix a Stretched or Loose Canvas: adım 1, 2 resimden 1. How to Fix a Stretched or Loose Canvas, How to Fix a Stretched or Loose Canvas: adım 1, 2 resimden 2.
    • Fill a spray bottle with water at room temperature.
    • In case that you do not have a spray bottle you can use a dishcloth and moisten it.
  2. How to Fix a Stretched or Loose Canvas: adım 2, 3 resimden 1. How to Fix a Stretched or Loose Canvas: adım 2, 3 resimden 2. How to Fix a Stretched or Loose Canvas: adım 2, 3 resimden 3.
    • Close the spray bottle tightly.
    • Turn the nozzle to spray.
  3. How to Fix a Stretched or Loose Canvas: adım 3, 2 resimden 1. How to Fix a Stretched or Loose Canvas: adım 3, 2 resimden 2.
    • Put a towel on a flat surface and lay the canvas face down on the towel.
  4. How to Fix a Stretched or Loose Canvas: adım 4, 3 resimden 1. How to Fix a Stretched or Loose Canvas: adım 4, 3 resimden 2. How to Fix a Stretched or Loose Canvas: adım 4, 3 resimden 3.
    • Carefully wet the entire backside of the canvas with the spray, or press water onto the canvas with the dishcloth.
    • Only spray until it is damp. Do not soak the canvas.
    • It does not matter if the canvas is new, old, has unfinished artwork or it is completed.
  5. How to Fix a Stretched or Loose Canvas: adım 5, 2 resimden 1. How to Fix a Stretched or Loose Canvas: adım 5, 2 resimden 2.
    • Turn on the dryer so warm air comes out.
  6. How to Fix a Stretched or Loose Canvas: adım 6, 3 resimden 1. How to Fix a Stretched or Loose Canvas: adım 6, 3 resimden 2. How to Fix a Stretched or Loose Canvas: adım 6, 3 resimden 3.
    • Blow dry the canvas with a hair dryer on warm until it's completely dry.
    • Keep the hair dryer at least 3 to 5 inches away from the canvas.
    • Do not place the hair dryer directly on the canvas. The heat from the hair dryer can burn the canvas.
  7. How to Fix a Stretched or Loose Canvas: adım 7, 2 resimden 1. How to Fix a Stretched or Loose Canvas: adım 7, 2 resimden 2.
    • Flip the canvas over and check that it is to your liking.
    • Flip the canvas again and double check.
    • Repeat the process again if the canvas is not completely fixed.
Sonuç
If it does not work, you should follow another guide where plaster is used in the canvas.
Bir başkası bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 10
Son 30 gün: 38
Her zaman: 2,497
