Ana içeriğe geç
How to Fix a T-shirt That's Too Big
Neye ihtiyacın var
  1. How to Fix a T-shirt That's Too Big, How to Fix a T-shirt That's Too Big: adım 1, 2 resimden 1. How to Fix a T-shirt That's Too Big, How to Fix a T-shirt That's Too Big: adım 1, 2 resimden 2.
    • Lay the larger T-shirt on a flat surface.
    • Make sure it sits perfectly flat and your side seams are in line.
    • Take another T-shirt that fits you perfectly and lay it on top of the larger T-shirt.
    • Double-check that the neckline is straight and the graphic on the larger T-shirt has plenty of room on either side.
  2. How to Fix a T-shirt That's Too Big: adım 2, 1 resimden 1.
    • Use a water-soluble fabric marker to trace the small T-shirt out on the larger one.
    • Leave some fabric allowance in case you need to fix anything or make adjustments.
  3. How to Fix a T-shirt That's Too Big: adım 3, 1 resimden 1.
    • Use scissors to cut off the excess material.
    • This will divide the shirt into three pieces: the body and two sleeves. Make sure to leave some seam allowance to make adjustments, if needed.
  4. How to Fix a T-shirt That's Too Big: adım 4, 1 resimden 1.
    • Using pins, put the sleeves together in order to give a crease.
    • Pin the rest of the unsewn edges to get a rough idea of whether it is the correct size.
  5. How to Fix a T-shirt That's Too Big: adım 5, 1 resimden 1.
    • Use your sewing machine to sew the parts of the shirt together.
    • Go back over with a smaller stitch to secure the parts of the shirt.
    • This guide uses white thread for visibility. Use a matching thread unless you want contrasting colors. Sew on the inside of the T-shirt to hide your seams.
  6. How to Fix a T-shirt That's Too Big: adım 6, 1 resimden 1.
    • Use scissors to cut any extra threads left over from the project.
Bitiş Çizgisi
3 farklı kişi bu kılavuzu tamamladı.
lakshay
185 İtibar
1 Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 10
Son 30 gün: 47
Her zaman: 1,601
