Ana içeriğe geç
How to Fix a Tear on a Leather Couch
Neye ihtiyacın var
  1. How to Fix a Tear on a Leather Couch, How to Fix a Tear on a Leather Couch: adım 1, 2 resimden 1. How to Fix a Tear on a Leather Couch, How to Fix a Tear on a Leather Couch: adım 1, 2 resimden 2.
    • Clean the area with small amount of alcohol on a damp washcloth.
  2. How to Fix a Tear on a Leather Couch: adım 2, 2 resimden 1. How to Fix a Tear on a Leather Couch: adım 2, 2 resimden 2.
    • Measure the length and width of the tear to determine how much subpatch will be needed.
    • Add an extra 1 cm border to each side.
    • Cut the subpatch according to the measurements.
  3. How to Fix a Tear on a Leather Couch: adım 3, 2 resimden 1. How to Fix a Tear on a Leather Couch: adım 3, 2 resimden 2.
    • Place the sub patch in the hole right behind the tear.
    • Position the sub patch to have 1 cm of excess cloth behind the border of the tear, so the thread can adhere to it.
    • Make a few stitches to secure the patch in place.
  4. How to Fix a Tear on a Leather Couch: adım 4, 2 resimden 1. How to Fix a Tear on a Leather Couch: adım 4, 2 resimden 2.
    • As an alternative to sewing, you can use vinyl or leather glue to secure the patch in place and close all the flaps of the tears on the surface of the subpatch.
    • Put an even layer of glue behind the border of the tear, adhering it to the patch.
  5. How to Fix a Tear on a Leather Couch: adım 5, 2 resimden 1. How to Fix a Tear on a Leather Couch: adım 5, 2 resimden 2.
    • Once the patch is stable and dry, use a spatula to apply the leather repair filler in the crevice until you have an even surface.
  6. How to Fix a Tear on a Leather Couch: adım 6, 2 resimden 1. How to Fix a Tear on a Leather Couch: adım 6, 2 resimden 2.
    • Use sandpaper to smoothen and even out the surface once it's dry.
    • Use the sandpaper to remove any excess filler or wipe it off with alcohol on a damp washcloth.
  7. How to Fix a Tear on a Leather Couch: adım 7, 2 resimden 1. How to Fix a Tear on a Leather Couch: adım 7, 2 resimden 2.
    • Brush over the heavy filler using a leather paint that matches the color of your sofa.
Bitiş Çizgisi
1Rehber Yorum
Where do you get this product
Carol Lewis - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 23
Son 30 gün: 95
Her zaman: 5,381
