Ana içeriğe geç
How to Fix a Thrustmaster Eswap X Pro Controller Trigger
Neye ihtiyacın var
  1. How to Fix a Thrustmaster Eswap X Pro Controller Trigger, How to Fix a Thrustmaster Eswap X Pro Controller Trigger: adım 1, 2 resimden 1. How to Fix a Thrustmaster Eswap X Pro Controller Trigger, How to Fix a Thrustmaster Eswap X Pro Controller Trigger: adım 1, 2 resimden 2.
    • Flip the controller so the backside is facing up.
    • Flip both of the switches away from the center.
  2. How to Fix a Thrustmaster Eswap X Pro Controller Trigger: adım 2, 3 resimden 1. How to Fix a Thrustmaster Eswap X Pro Controller Trigger: adım 2, 3 resimden 2. How to Fix a Thrustmaster Eswap X Pro Controller Trigger: adım 2, 3 resimden 3.
    • Flip the controller over so the top is facing up.
    • Pull out both the joystick and the directional pad modules.
  3. How to Fix a Thrustmaster Eswap X Pro Controller Trigger: adım 3, 3 resimden 1. How to Fix a Thrustmaster Eswap X Pro Controller Trigger: adım 3, 3 resimden 2. How to Fix a Thrustmaster Eswap X Pro Controller Trigger: adım 3, 3 resimden 3.
    • Flip the controller over again so the backside is facing up.
    • Use a spudger to remove five rubber screw covers.
  4. How to Fix a Thrustmaster Eswap X Pro Controller Trigger: adım 4, 3 resimden 1. How to Fix a Thrustmaster Eswap X Pro Controller Trigger: adım 4, 3 resimden 2. How to Fix a Thrustmaster Eswap X Pro Controller Trigger: adım 4, 3 resimden 3.
    • Use a Phillips #1 screwdriver to remove each of the 4.0 mm exposed screws.
  5. How to Fix a Thrustmaster Eswap X Pro Controller Trigger: adım 5, 2 resimden 1. How to Fix a Thrustmaster Eswap X Pro Controller Trigger: adım 5, 2 resimden 2.
    • Use a Phillips #1 screwdriver to loosen the captive screw and remove the trigger button.
  6. How to Fix a Thrustmaster Eswap X Pro Controller Trigger: adım 6, 3 resimden 1. How to Fix a Thrustmaster Eswap X Pro Controller Trigger: adım 6, 3 resimden 2. How to Fix a Thrustmaster Eswap X Pro Controller Trigger: adım 6, 3 resimden 3.
    • Rotate the controller 90 degrees.
    • Pull off the magnetic side cover.
  7. How to Fix a Thrustmaster Eswap X Pro Controller Trigger: adım 7, 3 resimden 1. How to Fix a Thrustmaster Eswap X Pro Controller Trigger: adım 7, 3 resimden 2. How to Fix a Thrustmaster Eswap X Pro Controller Trigger: adım 7, 3 resimden 3.
    • Lift the back cover slightly from where you removed the trigger button.
    • Use a Q-tip dipped with isopropyl alcohol to clean the surrounding area.
    • Additionally, wipe down the top face of the trigger with a Q-tip.
  8. How to Fix a Thrustmaster Eswap X Pro Controller Trigger: adım 8, 3 resimden 1. How to Fix a Thrustmaster Eswap X Pro Controller Trigger: adım 8, 3 resimden 2. How to Fix a Thrustmaster Eswap X Pro Controller Trigger: adım 8, 3 resimden 3.
    • Reattach the trigger button onto the controller.
    • Use a Phillips #1 screwdriver to tighten the screw securing trigger button.
  9. How to Fix a Thrustmaster Eswap X Pro Controller Trigger: adım 9, 3 resimden 1. How to Fix a Thrustmaster Eswap X Pro Controller Trigger: adım 9, 3 resimden 2. How to Fix a Thrustmaster Eswap X Pro Controller Trigger: adım 9, 3 resimden 3.
    • Use a Phillips #1 screwdriver to reattach the 4.0 mm screws to the back of the controller.
  10. How to Fix a Thrustmaster Eswap X Pro Controller Trigger: adım 10, 3 resimden 1. How to Fix a Thrustmaster Eswap X Pro Controller Trigger: adım 10, 3 resimden 2. How to Fix a Thrustmaster Eswap X Pro Controller Trigger: adım 10, 3 resimden 3.
    • Notice that the notches on the rubber covers correspond with the notches on the screw hole.
    • Reattach the rubber covers above the screws.
  11. How to Fix a Thrustmaster Eswap X Pro Controller Trigger: adım 11, 1 resimden 1.
    • Place the joystick and the directional pad modules back in their respective spots.
  12. How to Fix a Thrustmaster Eswap X Pro Controller Trigger: adım 12, 3 resimden 1. How to Fix a Thrustmaster Eswap X Pro Controller Trigger: adım 12, 3 resimden 2. How to Fix a Thrustmaster Eswap X Pro Controller Trigger: adım 12, 3 resimden 3.
    • Reattach the magnetic side cover.
    • The controller is fixed!
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Laurence Chan
268 İtibar
1 Kılavuz yazıldı
Ekip
UC Davis, Team 2-3, Morris Winter 2023 UC Davis, Team 2-3, Morris Winter 2023 üyesi
UCD-MORRIS-W23S2G3
2 Üyeler
1 Kılavuz yazıldı
3Kılavuz Yorumları
The problem is it keeps happening after doing all these steps. is there any way or parts to replace the trigger sensor completely? Possibly with a nice hall effect sensor?
John Addington - Yanıt
You can remove the lever bar that goes from the screw to the sensor (the one you see on Step 7)
Spray a small amount of WD40 on the sensor and use a prong to rotate the part on its full range of motion several times, that will clean up the contact inside and it completely fixed the jitter on mine.
Alex L -
hi, i made an account here just to say this worked for me but on the thrustmaster eswap S pro controller, it's almost identical aside from the cover panels
Anna Fiore - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 34
Son 30 gün: 125
Her zaman: 4,237
