Ana içeriğe geç
How to Fix a Tunneling Candle
Neye ihtiyacın var
  1. How to Fix a Tunneling Candle, How to Fix a Tunneling Candle: adım 1, 3 resimden 1. How to Fix a Tunneling Candle, How to Fix a Tunneling Candle: adım 1, 3 resimden 2. How to Fix a Tunneling Candle, How to Fix a Tunneling Candle: adım 1, 3 resimden 3.
    • Fill any kind of dish with hot water.
    • Add any brand of dish soap or hand soap to the water.
    • Mix the soap with water using a spoon.
  2. How to Fix a Tunneling Candle: adım 2, 2 resimden 1. How to Fix a Tunneling Candle: adım 2, 2 resimden 2.
    • Place the candle inside the mix of water and soap.
    • Let the jar soak inside the pot.
    • Make sure the area on the jar that has a label is completely soaked.
    • After 5 to 10 minutes, remove the candle from the dish.
  3. How to Fix a Tunneling Candle: adım 3, 1 resimden 1.
    • Use a sponge to wash and remove the label from the jar.
    • Removing the label helps you have a cleaner fix as it prevents the label from peeling off inside the boiling water and damaging your pot in future steps.
  4. How to Fix a Tunneling Candle: adım 4, 3 resimden 1. How to Fix a Tunneling Candle: adım 4, 3 resimden 2. How to Fix a Tunneling Candle: adım 4, 3 resimden 3.
    • Fill another pot with water and place it on the stove.
    • Turn the stove to high heat.
    • Wait until the water is simmering.
  5. How to Fix a Tunneling Candle: adım 5, 3 resimden 1. How to Fix a Tunneling Candle: adım 5, 3 resimden 2. How to Fix a Tunneling Candle: adım 5, 3 resimden 3.
    • Use oven mitts to place the candle inside the pot.
    • Wait 15 to 30 minutes for the wax to be fully melted.
  6. How to Fix a Tunneling Candle: adım 6, 3 resimden 1. How to Fix a Tunneling Candle: adım 6, 3 resimden 2. How to Fix a Tunneling Candle: adım 6, 3 resimden 3.
    • While waiting for the wax to melt, grab two coffee stir sticks or similar objects, and tape them into a cross.
    • In this guide, I am using incense sticks.
  7. How to Fix a Tunneling Candle: adım 7, 3 resimden 1. How to Fix a Tunneling Candle: adım 7, 3 resimden 2. How to Fix a Tunneling Candle: adım 7, 3 resimden 3.
    • Take the candle out of the pot using oven mitts.
    • Place the melted candle on a flat surface.
    • Remember to turn off the stove.
  8. How to Fix a Tunneling Candle: adım 8, 2 resimden 1. How to Fix a Tunneling Candle: adım 8, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Use a pair of tweezers to grab and pull out the burnt wick of the candle.
    • Do not touch the hot wax with your fingers; use tweezers.
  9. How to Fix a Tunneling Candle: adım 9, 3 resimden 1. How to Fix a Tunneling Candle: adım 9, 3 resimden 2. How to Fix a Tunneling Candle: adım 9, 3 resimden 3.
    • Place the cross that you made from the sticks on the edges of the candle jar.
    • Insert two new candle wicks inside the wax from the metal side.
    • Make sure the wicks are not close together.
    • Twist the wick around the sticks to prevent them from moving.
  10. How to Fix a Tunneling Candle: adım 10, 3 resimden 1. How to Fix a Tunneling Candle: adım 10, 3 resimden 2. How to Fix a Tunneling Candle: adım 10, 3 resimden 3.
    • Wait for the wax to harden and remove the sticks.
    • Trim the candle wick to 1/4 inch.
    • You have fixed your tunneling candle.
Bitiş Çizgisi
2 farklı kişi bu kılavuzu tamamladı.
[deleted]
245 İtibar
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 12
Her zaman: 1,541
