Ana içeriğe geç
How to Fix a Wobbling Y-Axis on a Creality Ender-3 Pro 3D Printer
Neye ihtiyacın var
  1. How to Fix a Wobbling Y-Axis on a Creality Ender-3 Pro 3D Printer, How to Fix a Wobbling Y-Axis on a Creality Ender-3 Pro 3D Printer: adım 1, 2 resimden 1. How to Fix a Wobbling Y-Axis on a Creality Ender-3 Pro 3D Printer, How to Fix a Wobbling Y-Axis on a Creality Ender-3 Pro 3D Printer: adım 1, 2 resimden 2.
    • Unscrew the leveling wheels under the bed and remove the print bed from its brackets.
  2. How to Fix a Wobbling Y-Axis on a Creality Ender-3 Pro 3D Printer: adım 2, 1 resimden 1.
    • Use the 6 mm open-end wrench to hold the bottom of the bolt connections that are not in contact with the railing, then loosen the bolts with a 3 mm hex key.
    • Do not remove the bolts, as this could move the bolt connection further from the railing.
  3. How to Fix a Wobbling Y-Axis on a Creality Ender-3 Pro 3D Printer: adım 3, 1 resimden 1.
    • Orient the eccentric nut with the 10 mm open-end wrench, turning it until the wheel bearing is in contact with the rail.
  4. How to Fix a Wobbling Y-Axis on a Creality Ender-3 Pro 3D Printer: adım 4, 1 resimden 1.
    • Hold the bottom of the loosened bolt-connection with the 6 mm open-end wrench, then refasten the bolt with a 3 mm hex key.
    • Do not overtighten the bolt connection as this could strip the screw head.
  5. How to Fix a Wobbling Y-Axis on a Creality Ender-3 Pro 3D Printer: adım 5, 1 resimden 1.
    • Test the wheel bearing for slippage, using your fingers to attempt to turn the wheel bearing.
    • If slippage remains persistent, repeat steps 2-5 until the wheel bearing does not slip on the rail guide when tested.
  6. How to Fix a Wobbling Y-Axis on a Creality Ender-3 Pro 3D Printer: adım 6, 2 resimden 1. How to Fix a Wobbling Y-Axis on a Creality Ender-3 Pro 3D Printer: adım 6, 2 resimden 2.
    • Place the print bed back over its bracket, refastening it with the leveling wheels.
Sonuç
Your y-axis should now be secured without the worry of misprinted layers. Happy printing!
6 farklı kişi bu kılavuzu tamamladı.
Bir Yorum
Just want to say this is by far the most helpful of all how to articles I saw to address this issue. Thank you
John Harris - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 25
Son 30 gün: 159
Her zaman: 10,182
