Ana içeriğe geç
How to Fix a Wobbly Wolf Warriors Gaming Chair Leg Rest
Neye ihtiyacın var
  1. How to Fix a Wobbly Wolf Warriors Gaming Chair Leg Rest, How to Fix a Wobbly Wolf Warriors Gaming Chair Leg Rest: adım 1, 2 resimden 1. How to Fix a Wobbly Wolf Warriors Gaming Chair Leg Rest, How to Fix a Wobbly Wolf Warriors Gaming Chair Leg Rest: adım 1, 2 resimden 2.
    • Lean back the chair and extend the leg rest completely.
  2. How to Fix a Wobbly Wolf Warriors Gaming Chair Leg Rest: adım 2, 1 resimden 1.
    • Lay the chair on its side on the ground to allow easier access to the required hex screws and blocker screw.
  3. How to Fix a Wobbly Wolf Warriors Gaming Chair Leg Rest: adım 3, 3 resimden 1. How to Fix a Wobbly Wolf Warriors Gaming Chair Leg Rest: adım 3, 3 resimden 2. How to Fix a Wobbly Wolf Warriors Gaming Chair Leg Rest: adım 3, 3 resimden 3.
    • Remove the 3 mm blocker screw using a 3mm Allen wrench/hex key.
  4. How to Fix a Wobbly Wolf Warriors Gaming Chair Leg Rest: adım 4, 1 resimden 1.
    • Slide the leg rest out of the base.
  5. How to Fix a Wobbly Wolf Warriors Gaming Chair Leg Rest: adım 5, 2 resimden 1. How to Fix a Wobbly Wolf Warriors Gaming Chair Leg Rest: adım 5, 2 resimden 2.
    • Place the leg rest on a flat surface.
    • Wipe clean the sliding legs using a clean cloth to ensure the sliding mechanism has no issues.
  6. How to Fix a Wobbly Wolf Warriors Gaming Chair Leg Rest: adım 6, 3 resimden 1. How to Fix a Wobbly Wolf Warriors Gaming Chair Leg Rest: adım 6, 3 resimden 2. How to Fix a Wobbly Wolf Warriors Gaming Chair Leg Rest: adım 6, 3 resimden 3.
    • Tighten the four 25 mm hex screws located at the bottom of the chair using the 3 mm Allen key.
    • Be careful not to over tighten the 25 mm hex screws. This can cause the screw to become free from the base.
  7. How to Fix a Wobbly Wolf Warriors Gaming Chair Leg Rest: adım 7, 1 resimden 1.
    • Slide the leg rest back into the base.
  8. How to Fix a Wobbly Wolf Warriors Gaming Chair Leg Rest: adım 8, 2 resimden 1. How to Fix a Wobbly Wolf Warriors Gaming Chair Leg Rest: adım 8, 2 resimden 2.
    • Screw the 3 mm blocker screw back in.
    • Flip your chair back up and enjoy your sturdy leg rest!
Sonuç
Anoop Shahi
157 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 17
Her zaman: 405
