Ana içeriğe geç
How to Fix an OXO Container's Jammed Button
Neye ihtiyacın var
  1. How to Fix an OXO Container's Jammed Button, How to Fix an OXO Container's Jammed Button: adım 1, 3 resimden 1. How to Fix an OXO Container's Jammed Button, How to Fix an OXO Container's Jammed Button: adım 1, 3 resimden 2. How to Fix an OXO Container's Jammed Button, How to Fix an OXO Container's Jammed Button: adım 1, 3 resimden 3.
    • Hold the lid with the button facing down.
    • Twist the flat part in the direction of the arrows or counter clockwise.
  2. How to Fix an OXO Container's Jammed Button: adım 2, 3 resimden 1. How to Fix an OXO Container's Jammed Button: adım 2, 3 resimden 2. How to Fix an OXO Container's Jammed Button: adım 2, 3 resimden 3.
    • Firmly pinch both the half-moon shaped openings.
    • Pull up the removed outer piece and set it aside.
  3. How to Fix an OXO Container's Jammed Button: adım 3, 1 resimden 1.
    • Place the lid perpendicular and onto the top of the container's opening.
    • The button should pop out. Placing the lid on a flat surface will prevent them from coming out.
    • Locate the two holes.
  4. How to Fix an OXO Container's Jammed Button: adım 4, 2 resimden 1. How to Fix an OXO Container's Jammed Button: adım 4, 2 resimden 2.
    • With a tool in each hand, insert them into the openings of the buttons.
    • Make sure the two tools are centered on the plastic in the openings.
    • Tools must be small enough to fit inside the openings - alternatives to spudgers work.
    • Firmly press downwards until the button pops out.
    • Applying a lot of pressure is necessary, but also may damage the plastic of the lid.
  5. How to Fix an OXO Container's Jammed Button: adım 5, 2 resimden 1. How to Fix an OXO Container's Jammed Button: adım 5, 2 resimden 2.
    • Flip the lid so the button faces up.
    • It should be easy to pinch the sides of the button so that it pops up.
    • Pinch the two sides and gently pull up.
    • Remove the button.
  6. How to Fix an OXO Container's Jammed Button: adım 6, 3 resimden 1. How to Fix an OXO Container's Jammed Button: adım 6, 3 resimden 2. How to Fix an OXO Container's Jammed Button: adım 6, 3 resimden 3.
    • Flip the button so the inside wire faces upwards.
    • Use pliers to bend the wire similar to its original shape.
    • Use the unbent wire as a reference to reshape the bent wire.
Sonuç
To reassemble your device, squeeze the button back onto the lid and follow these instructions in reverse order.
Allen Wong
133 İtibar
1 Kılavuz yazıldı
Ekip
UC Davis, Team 2-5, Andersen Winter 2023 UC Davis, Team 2-5, Andersen Winter 2023 üyesi
UCD-ANDERSEN-W23S2G5
3 Üyeler
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 27
Son 30 gün: 125
Her zaman: 6,123
