Ana içeriğe geç
How to Fix an Unstable Ikea Poang Chair
Neye ihtiyacın var
  1. How to Fix an Unstable Ikea Poang Chair, How to Fix an Unstable Ikea Poang Chair: adım 1, 1 resimden 1.
    • Start by removing the seat cushion from the frame.
  2. How to Fix an Unstable Ikea Poang Chair: adım 2, 3 resimden 1. How to Fix an Unstable Ikea Poang Chair: adım 2, 3 resimden 2. How to Fix an Unstable Ikea Poang Chair: adım 2, 3 resimden 3.
    • Remove the upper bolt, which attaches the back of the seat to the armrests.
    • Remove the lower bolt, which is the upper bolt attaching the seat to the legs.
    • Remove the same bolts on the opposite side of the chair.
    • To loosen the bolts, turn the Allen wrench to the LEFT, as shown in the video.
  3. How to Fix an Unstable Ikea Poang Chair: adım 4, 1 resimden 1.
    • Separate the back and seat of the chair from the legs and the armrest.
  4. How to Fix an Unstable Ikea Poang Chair: adım 5, 2 resimden 1. How to Fix an Unstable Ikea Poang Chair: adım 5, 2 resimden 2.
    • Re-attach the bolts removed in Steps 2 and 3. Put each bolt into the correct location before tightening each bolt.
    • If the bolt attaching the seat tightens too easily, it is not in the hole and rests above or below the wood of the seat. This is what causes the tipping or dipping of the seat.
    • When attaching the bolt for the back of the chair, insert a plastic washer between the wood of the chair leg and the wood of the chair back. Without this washer, the two pieces will not sit flush. This allows the chair to shift and may cause the chair to become unstable.
    • For maximum stability, fully tighten all of the bolts in the chair.
    • As shown in the video, tighten by turning the Allen wrench to the RIGHT.
  5. How to Fix an Unstable Ikea Poang Chair: adım 7, 1 resimden 1.
    • Set the chair cushion on the chair seat.
    • Secure the Velcro on the cushion to the Velcro on the chair back.
Bitiş Çizgisi
2 farklı kişi bu kılavuzu tamamladı.
Erik Romanski
164 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 17
Son 30 gün: 112
Her zaman: 15,061
