Ana içeriğe geç
How to Fix an Xbox One Controller Stuck Button
Neye ihtiyacın var
  1. How to Fix an Xbox One Controller Stuck Button, How to Fix an Xbox One Controller Stuck Button: adım 1, 3 resimden 1. How to Fix an Xbox One Controller Stuck Button, How to Fix an Xbox One Controller Stuck Button: adım 1, 3 resimden 2. How to Fix an Xbox One Controller Stuck Button, How to Fix an Xbox One Controller Stuck Button: adım 1, 3 resimden 3.
    • Use an opening tool to remove the back panels of the controller.
  2. How to Fix an Xbox One Controller Stuck Button: adım 2, 3 resimden 1. How to Fix an Xbox One Controller Stuck Button: adım 2, 3 resimden 2. How to Fix an Xbox One Controller Stuck Button: adım 2, 3 resimden 3.
    • Remove the five screws from the back of the controller.
    • The 5th screw is behind the sticker in the battery compartment.
  3. How to Fix an Xbox One Controller Stuck Button: adım 3, 3 resimden 1. How to Fix an Xbox One Controller Stuck Button: adım 3, 3 resimden 2. How to Fix an Xbox One Controller Stuck Button: adım 3, 3 resimden 3.
    • Remove the front and back covers.
    • Remove the screws on the inside.
  4. How to Fix an Xbox One Controller Stuck Button: adım 4, 3 resimden 1. How to Fix an Xbox One Controller Stuck Button: adım 4, 3 resimden 2. How to Fix an Xbox One Controller Stuck Button: adım 4, 3 resimden 3.
    • Remove the screws.
    • Flip the controller over and remove the joysticks.
  5. How to Fix an Xbox One Controller Stuck Button: adım 5, 2 resimden 1. How to Fix an Xbox One Controller Stuck Button: adım 5, 2 resimden 2.
    • Remove both screws near the trigger.
  6. How to Fix an Xbox One Controller Stuck Button: adım 6, 3 resimden 1. How to Fix an Xbox One Controller Stuck Button: adım 6, 3 resimden 2. How to Fix an Xbox One Controller Stuck Button: adım 6, 3 resimden 3.
    • Remove the triggers to create more space.
    • Remove the screws holding the motherboard.
  7. How to Fix an Xbox One Controller Stuck Button: adım 7, 3 resimden 1. How to Fix an Xbox One Controller Stuck Button: adım 7, 3 resimden 2. How to Fix an Xbox One Controller Stuck Button: adım 7, 3 resimden 3.
    • Remove the screws underneath the first chip board.
  8. How to Fix an Xbox One Controller Stuck Button: adım 8, 3 resimden 1. How to Fix an Xbox One Controller Stuck Button: adım 8, 3 resimden 2. How to Fix an Xbox One Controller Stuck Button: adım 8, 3 resimden 3.
    • Remove all screws holding the motherboard.
    • Pry open the top of the controller to release the motherboard.
  9. How to Fix an Xbox One Controller Stuck Button: adım 9, 3 resimden 1. How to Fix an Xbox One Controller Stuck Button: adım 9, 3 resimden 2. How to Fix an Xbox One Controller Stuck Button: adım 9, 3 resimden 3.
    • Remove the motherboard.
    • Remove the buttons.
  10. How to Fix an Xbox One Controller Stuck Button: adım 10, 3 resimden 1. How to Fix an Xbox One Controller Stuck Button: adım 10, 3 resimden 2. How to Fix an Xbox One Controller Stuck Button: adım 10, 3 resimden 3.
    • Clean the new buttons with rubbing alcohol for less friction.
    • Clean the controller frame holes.
Sonuç
Bir başkası bu kılavuzu tamamladı.
iAmChrisBro
218 İtibar
1 Kılavuz yazıldı
Ekip
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 38
Son 30 gün: 228
Her zaman: 4,206
