Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Parçalar ve Aletler
Giriş
Because of its unique convenience and security, Hey Siri has been a frequently used function for iPhone users. Without touching the screen, users can free their hands by manipulating Siri to text someone, make phone calls, check routes, etc.. Today, we are sharing with you one Hey Siri unresponsive repair case.
Videoya Genel Bakış
  1. Go to the home screen and invoke Siri by muttering the words ‘Hey Siri’. Siri isn’t opening on the phone.
    • Go to the home screen and invoke Siri by muttering the words ‘Hey Siri’. Siri isn’t opening on the phone.
    • Go to Settings > Siri & Search. We can see that ‘Listen for Hey Siri’ has not been enabled.
    • Enable ‘Listen for Hey Siri’. Set up ‘Hey Siri’ on the phone. ‘Hey Siri’ set-up failed.
    • Long press the home button for Siri. Siri works normally.
    • As the front facing microphone is usually used for Siri. The fault is probably related to relevant circuits of the front facing microphone.
  2. Take apart the phone. Then take out the logic board.
    • Take apart the phone. Then take out the logic board.
    • Since the front facing microphone is integrated with the front facing camera, we need to run diode mode measurement of the front facing camera connector.
    • The measured value of Pin 29 is OL. Which means Pin 29 relevant circuit has open-circuited.
  3. Nintendo Switch Kit'leri
    Oyuna geri dönmek için hızlı bir düzeltme
    Switch Kit'leri Satın Al
  4. The circuit is formed by an inductor, audio IC and two capacitors.
    • The circuit is formed by an inductor, audio IC and two capacitors.
    • Since the two capacitors have nothing to do with the open-circuit problem, we can check the inductor first.
    • Run diode mode measurement of the inductor. The measured value is normal.
  5. Judging by this, the fault is probably related to audio IC.
    • Judging by this, the fault is probably related to audio IC.
    • Let’s try to replace with a new audio IC and see how it works.
    • Remove the audio IC with Hot Air Gun. Then clean the bonding pad. Solder a new IC onto the board.
  6. Now we need to test the logic board. Measure the boot current. The current reading is normal.
    • Now we need to test the logic board. Measure the boot current. The current reading is normal.
    • Continue to assemble the phone and test. The phone turns on normally. Go to Settings > Siri & Search. We can see that ‘Listen for Hey Siri’ has not been enabled.
    • Enable ‘Listen for Hey Siri’ and set up ‘Hey Siri’ on the phone. ‘Hey Siri’ set-up has been completed.
    • Go back to the home screen and invoke Siri by muttering the words ‘Hey Siri’. Siri is opening on the phone this time.
Bitiş Çizgisi
3 farklı kişi bu kılavuzu tamamladı.
Phryne
8.208 İtibar
63 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 10
Son 30 gün: 70
Her zaman: 367
