Giriş
No one notices the direction that a clothes dryer door opens until it is a problem. The dryer door swing may need to be reversed depending on what side of the washing machine it sits on, or where it is in a laundry room. Our Fast Fix guide will document the process used to fix the swing direction of an LG DLEX5170W SteamDryer door.
Before you begin, make sure the dryer is unplugged and you are in an open space with sufficient room.
Neye ihtiyacın var
Remove the two 150 mm Phillips #2 screws from each of the two hinges on the inside of the door.
Remove the door.
Reversing the dryer door swing is a simple and quick process. Completing this project can save you time and frustration by allowing your dryer door to open freely in the direction you need.
2 farklı kişi bu kılavuzu tamamladı.
2 Yorum
Directions are very clear and accurate. Not difficult!
I looked everywhere for directions on how to reverse the door on my dryer, but couldn't find any. The instructions in the LG manual were useless and there was nothing on YouTube that pertained to my dryer. I was ready to call an appliance repairman and then I found you. Your instructions were easy and very clear. I now have a dryer door that works. Thank you. Thank you.
