Ana içeriğe geç
How to Fix the James Donkey RS2 2.0 Switch or Motherboard
Neye ihtiyacın var
  1. How to Fix the James Donkey RS2 2.0 Switch or Motherboard, Switch or Motherboard: adım 1, 2 resimden 1. How to Fix the James Donkey RS2 2.0 Switch or Motherboard, Switch or Motherboard: adım 1, 2 resimden 2.
    • The first step is to disassemble all the pieces to make sure all the parts are separated.
  2. How to Fix the James Donkey RS2 2.0 Switch or Motherboard: adım 2, 2 resimden 1. How to Fix the James Donkey RS2 2.0 Switch or Motherboard: adım 2, 2 resimden 2.
    • Make sure all the cable is unplugged to prevent an accident from happening.
  3. How to Fix the James Donkey RS2 2.0 Switch or Motherboard: adım 3, 3 resimden 1. How to Fix the James Donkey RS2 2.0 Switch or Motherboard: adım 3, 3 resimden 2. How to Fix the James Donkey RS2 2.0 Switch or Motherboard: adım 3, 3 resimden 3.
    • Unplug all the cables before removing any other parts of the keyboard.
  4. How to Fix the James Donkey RS2 2.0 Switch or Motherboard: adım 4, 3 resimden 1. How to Fix the James Donkey RS2 2.0 Switch or Motherboard: adım 4, 3 resimden 2. How to Fix the James Donkey RS2 2.0 Switch or Motherboard: adım 4, 3 resimden 3.
    • Unscrew the small board (including 2 m 2 4 mm screws) to make it easier to figure out where the trouble is.
  5. How to Fix the James Donkey RS2 2.0 Switch or Motherboard: adım 5, 2 resimden 1. How to Fix the James Donkey RS2 2.0 Switch or Motherboard: adım 5, 2 resimden 2.
    • Then plug it back into the PCB. What we get will be a small board connected to the big board.
  6. How to Fix the James Donkey RS2 2.0 Switch or Motherboard: adım 6, 1 resimden 1.
    • Connect the board to the computer, and turn the circuit on to test to see where the problem is.
  7. How to Fix the James Donkey RS2 2.0 Switch or Motherboard: adım 7, 1 resimden 1.
    • To figure out if is it connected or not, first open the key tester on a computer that has been connected to the keyboard.
  8. How to Fix the James Donkey RS2 2.0 Switch or Motherboard: adım 8, 1 resimden 1.
    • Use the metal tweezer to connect the silver part under the PCB.
  9. How to Fix the James Donkey RS2 2.0 Switch or Motherboard: adım 9, 1 resimden 1.
    • If everything works fine, it should light in green, which means the key has been sensed.
  10. How to Fix the James Donkey RS2 2.0 Switch or Motherboard: adım 10, 1 resimden 1.
    • If there is just one single key that is unable to react, then switch it.
  11. How to Fix the James Donkey RS2 2.0 Switch or Motherboard: adım 11, 1 resimden 1.
    • If there is a line that has no reaction, which means PCB is malfunctioning, send it back for repair.
  12. How to Fix the James Donkey RS2 2.0 Switch or Motherboard: adım 12, 2 resimden 1. How to Fix the James Donkey RS2 2.0 Switch or Motherboard: adım 12, 2 resimden 2.
    • Here is how to switch the switches. First, unplug the keycap.
  13. How to Fix the James Donkey RS2 2.0 Switch or Motherboard: adım 13, 2 resimden 1. How to Fix the James Donkey RS2 2.0 Switch or Motherboard: adım 13, 2 resimden 2.
    • Then unplug the switch.
  14. How to Fix the James Donkey RS2 2.0 Switch or Motherboard: adım 14, 3 resimden 1. How to Fix the James Donkey RS2 2.0 Switch or Motherboard: adım 14, 3 resimden 2. How to Fix the James Donkey RS2 2.0 Switch or Motherboard: adım 14, 3 resimden 3.
    • After that, plug in a new switch.
  15. How to Fix the James Donkey RS2 2.0 Switch or Motherboard: adım 15, 2 resimden 1. How to Fix the James Donkey RS2 2.0 Switch or Motherboard: adım 15, 2 resimden 2.
    • Finally, put back the keycap.
  16. How to Fix the James Donkey RS2 2.0 Switch or Motherboard: adım 16, 2 resimden 1. How to Fix the James Donkey RS2 2.0 Switch or Motherboard: adım 16, 2 resimden 2.
    • Congratulations! You are done with the replacement. Now put the board back, screw it with 2 4 mm M2 screws, and connect all the cables.
  17. How to Fix the James Donkey RS2 2.0 Switch or Motherboard: adım 17, 3 resimden 1. How to Fix the James Donkey RS2 2.0 Switch or Motherboard: adım 17, 3 resimden 2. How to Fix the James Donkey RS2 2.0 Switch or Motherboard: adım 17, 3 resimden 3.
    • When everything is done, put back the top layer.
Sonuç
Yichen Gu
265 İtibar
1 Kılavuz yazıldı
Ekip
Bir Yorum
I am attempting to repair my keyboard now. my issue is the only key that does not work is the Windows key. All others work. there is no visible damage and when I press the key the LED still lights up. I jumped the pins and while I get the LED to light up, I still get no detection on windows
Alex Craig - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 17
Her zaman: 367
