Ana içeriğe geç
How to Force Restart an iPhone 5
  1. How to Force Restart an iPhone 5, How to Force Restart an iPhone 5: adım 1, 2 resimden 1. How to Force Restart an iPhone 5, How to Force Restart an iPhone 5: adım 1, 2 resimden 2.
    • Press and hold the Home button.
    • While holding the Home button, press and hold the Sleep/Wake button.
    What if the Sleep/Wake button ain't working? any alternative?
    iman.casssidy - Yanıt
  2. How to Force Restart an iPhone 5: adım 2, 2 resimden 1. How to Force Restart an iPhone 5: adım 2, 2 resimden 2.
    • Continue holding both buttons for about 10 seconds, until the Apple logo appears.
    What if it's still on the Apple logo screen
    divineking413 - Yanıt
    Rebort my iPhone 5 but still frozen 3 hours after
    sandrahughes61 - Yanıt
    Sorry (for me) this doesn’t work on my iPhone 5. Using this method toggles my iPhone between the solid black screen and the Apple logo on a black screen — that’s all I get. I cannot get anything else. If (after I use this method and get a solid black screen) I just press the sleep/wake button, the Apple logo once again appears and stays. That’s it.
    patc_quincy - Yanıt
    My iPhone the button at the top is pushed down to far I cant use it
    Payton Smith - Yanıt
    thnanks buddy
    thilan - Yanıt
    I tried this also and just got the Apple logo for about 20 seconds and then the screen goes black.
    I replaced the battery to see if this was the problem , but still does not come on.. Any suggestions
    madmomma- Sept. 16 2018
    irene sheridan - Yanıt
    After I reset my phone I does the same thing. It goes back to the page that says hello
    Latavia Kates - Yanıt
    Doesn’t work for me either. Apple logo never appears.
    cdrjimparham - Yanıt
    My phone keeps going from the apple logo to a black screen and sometimes it goes to a red screen and it keeps flashing. I tried to do this method and it didn't work. What should I do?
    EMAYA ALLEN - Yanıt
Bitiş Çizgisi
264 farklı kişi bu kılavuzu tamamladı.
Dante Mazzanti
36.171 İtibar
26 adet Kılavuz yazıldı
45 Yorum
What happens if this does not work with an IPhone with a white screen
patrick noonan - Yanıt
https://www.youtube.com/watch?v=aSG0Moj5... this video fix iphone white apple logo screen and iphone stuck.
Li Mike -
it means, that you have white iphone :D
Mitja Herbaj - Yanıt
does this work with water damaged phone?
illonatrinacesante - Yanıt
Worked great with my seemingly dead iPhone 5s
biyahero - Yanıt
it helps me a lot thanks
custard - Yanıt
not working after holding for 30 seconds
krishnavenigolconda - Yanıt
Worked like a charm. Is this magic, or what.
eogord - Yanıt
Omg its not working......WHY MEE!!
ariyanna - Yanıt
worked great, thanks for your help.
jrpace2 - Yanıt
iPhone is spinning and won't reboot how can I fix the problem
Darsean Greene - Yanıt
Sorted.....thanks
morrrany - Yanıt
thanks a lot man!
Fani Azmi - Yanıt
if my iphone Sleep/Wake button not working , still got another way to restart my phone?
shiahooi0312 - Yanıt
Exact same problem here :(
iman.casssidy -
Same here. Any solutions?
Miche Lynch -
Now how can I force shutdown the phone without it starting back up? The screen/digitizer is broken, so I can't do the normal power-off and the two-button procedure is a reboot - not power-off.
Chris Wolf - Yanıt
hey man its really helpful thanks a lot for this imp step !!!
praveen.friendly23 - Yanıt
My phone shut off and would not turn back on. Worked Perfect. Thank YOU!
tori.blomquist - Yanıt
what if the sleep/wake button isnt working?
Lei-Anne Balubar - Yanıt
Its help me a lot..... Thank u so muchhh
jassy_1995 - Yanıt
Searching ...... appears on my phone at the left corner. It's seem to be stuck. Calls continue to fail, What should I do?
Cakeado - Yanıt
The Home button of the iPhone 5s is not working, I can know how it will work.
Gurjindra - Yanıt
My phone has frozen and my home button is broken, cant get notifications on my phone as they dont appear on the screen or allow me to swipe down. Can’t log in to icloud and manually restart it because you need to enter a verification code, and i cant get it.
wiqz bob - Yanıt
i need iphone 7 gold display (my no 00919746186927) please help me
jabbar - Yanıt
apple 5c touch not working
help me
deepak semwal - Yanıt
It doesn't work with me.. It show me the apple mark and shut down immediately again... Please help me to wake it up again
Mostafa - Yanıt
My menu button isn’t working. How do I force restart
Victoria - Yanıt
It did not work
my iphone s5 icloud locked ho remove
Sajjad Ali - Yanıt
My iPhone is iPhone disabled Connect to itune problem
Vishvanath - Yanıt
Just completed this repair with an iPhone 5 whose battery had swollen to the point that the screen detached from the case. This actually made the repair easier, as removing the screen and battery had basically already been done for me by the device itself. I got the battery and Ifixit toolkit, but it turned out I already owned the tools needed. So, extras, I guess.
Michael Stern - Yanıt
And then what when that doesn’t work?
mdpomroy - Yanıt
My IPhone 5s is disabled, how do I get it to restart it again and work properly? It was working fine yesterday, but now its messed up!
Gerardo Gaddi - Yanıt
Thanks a lot for your information. iphone 5s is good .
Khin - Yanıt
its not working
hastings sichali - Yanıt
My home button was broken any other ways?
hilbertosabinorio - Yanıt
Will this work when the screen is stuck on connect to iTunes ?
brian spillane - Yanıt
I tried the hold…it does not work… is there any other way to get the data from my dead iphone5?
sbermansells - Yanıt
My 5s iPhone is dead, only the apple figure comes out and does nothing else. I already let it discharge the battery and charged it again but without any positive results.
oPaz Paz - Yanıt
This troubleshooting page might help you: iPhone is Charging but Won't Turn On
Tobias Isakeit -
My Iphone 5 Screen is Freezing and sometimes the Icons are not moving and sometimes when to click on for typing, suddenly it will type automatically on his screen? What seems to be the problem with the Display that works alone typing anything? Ha ha… it looks like there is something stock on the LCD my guest? As you can see this Iphone 5 proves to me a lot for a very long time of usages. I have done the Force to Restart but nothing is changing? What could be the problem? Will I have to Replace my LCD or else?
E . D. Prudencio - Yanıt
Sorry didnot work, I believe the iPhone is a brick. Thanks for your help.
Tony
amckayt - Yanıt
I did the same thing but its not working i tried unplugging and re plugging the screen but still didnt work it restore it to still didnt work it took it to a phone repair man he tried with new screen still didnt work soo do you know how to fix it?
Mehmet - Yanıt
How to reatores the Iphone5 from zero and It says inativo..
André Cobra - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 17
Son 7 gün: 174
Son 30 gün: 717
Her zaman: 464,621
