Ana içeriğe geç
How to Hand Sew Patches Onto a Garment
Neye ihtiyacın var
  1. How to Hand Sew Patches Onto a Garment, How to Hand Sew Patches Onto a Garment: adım 1, 1 resimden 1.
    • Place the cardboard separator in between the layers of your chosen garment.
    • This helps to avoid stitching both sides of the garment together.
  2. How to Hand Sew Patches Onto a Garment: adım 2, 1 resimden 1.
    • Choose a color of thread that matches or contrasts with the color of your patch.
  3. How to Hand Sew Patches Onto a Garment: adım 3, 2 resimden 1. How to Hand Sew Patches Onto a Garment: adım 3, 2 resimden 2.
    • Choose where you’d like the patch to sit on the garment.
    • To help with stability, use pins and iron the garment to maintain the position of the patch.
  4. How to Hand Sew Patches Onto a Garment: adım 4, 2 resimden 1. How to Hand Sew Patches Onto a Garment: adım 4, 2 resimden 2.
    • Push the thread through the eye of the needle.
    • To prevent fraying, twist the ends of the thread to tighten it.
  5. How to Hand Sew Patches Onto a Garment: adım 5, 3 resimden 1. How to Hand Sew Patches Onto a Garment: adım 5, 3 resimden 2. How to Hand Sew Patches Onto a Garment: adım 5, 3 resimden 3.
    • Insert the needle through the backside of the shirt and patch.
    • Pull the needle until the thread is taut.
    • Insert the needle through the outside of the shirt and patch, at the length you’d like your stitch to be.
    • Pull the needle again until the thread is taut.
  6. How to Hand Sew Patches Onto a Garment: adım 6, 3 resimden 1. How to Hand Sew Patches Onto a Garment: adım 6, 3 resimden 2. How to Hand Sew Patches Onto a Garment: adım 6, 3 resimden 3.
    • On the backside, insert the needle at a similar distance to the previous stitch, away from the previous stitch.
    • Insert the needle at the end of the previous stitch; this will be stitching backwards.
  7. How to Hand Sew Patches Onto a Garment: adım 7, 3 resimden 1. How to Hand Sew Patches Onto a Garment: adım 7, 3 resimden 2. How to Hand Sew Patches Onto a Garment: adım 7, 3 resimden 3.
    • Lace the needle through the extra fabric of the shirt that is covered by the patch.
    • Hold both ends of your thread and rotate it around the needle twice.
    • Create a loop using the thread and pull your needle through the loop.
    • Pull until the knot has formed (no extra thread is leftover).
    • Cut the thread with 1-2 inches to spare.
  8. How to Hand Sew Patches Onto a Garment: adım 8, 1 resimden 1.
    • Finished Product!
Bitiş Çizgisi
Bir başkası bu kılavuzu tamamladı.
Shannon Ikemiya
178 İtibar
1 Kılavuz yazıldı
Ekip
UC Davis, Team 2-1, Whithaus Spring 2024 UC Davis, Team 2-1, Whithaus Spring 2024 üyesi
UCD-WHITHAUS-S24S2G1
4 Üyeler
2 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 9
Son 30 gün: 55
Her zaman: 421
