Giriş
Samsung Galaxy A5
If your phone is screen locked and you can't enter into the menu with your google account or if you have a problem with the OS you can do a Factory Reset.
This will erase all device settings, user data, third-party applications, and associated application data from an Android device’s internal flash storage and will return the device to the condition it was in when shipped from the factory.
Videoya Genel Bakış
Switch off the phone.
Press and hold the Volume Up, Home and Power buttons.
When you see the Galaxy logo release only the Power button.
Use the Volume Up/Down buttons for navigation and the Power button for choice.
From the android system recovery menu select:
wipe data/factory reset
Yes -- delete all user data
reboot system now
That's all.
Did you do it successfully?
Now my phone showing downloading was what can I do now
i have done the same as you did, still downloading since yesterday. really need help hun,
Thankyou so much for this help system it really worked out. And now my phone is working properly
It is still asking for a privecy protection code
Thank you so so much!!
your instructions really helped me alot, now my Samsung A5 is back to normal
now i cant start my phone... whats happening??
Me To, did you find an issue ??
Thanks for giving me idea
Does not work,my phone is still downloadin after 10hrs
Hold down and power until the phone goes off
Satchmo -
i cant even switch off my mobile. its hangged,
mine to, I did mine yesterday and now its still hanging. what do I do, please help me, thank s
Not possible to switch it off without unlocking it.
Hold down and power unit it goes off
Satchmo -
Bonjour
une fois la selection reset now .le tel se rallume directement. Que faire?
merci pour votre aide
I was give by office a Samsung A5 phone, our ex boss used, now we are unable to log in to use the phone, no matter what we do
Worked the first time for me. Thank you for the clear instructions.
Thank you for the help. My phone is working now.
mine just goes back to the main menu. it says “failed to find /misc partition”
No pude solo enciende el teléfono pero no me manda a recobery ya me cansé mejor lo voy a hechar a la basura ?
Not possible to switch off Samsung A5 without unlocking it. What can I do.
This essentially bricked my phone! It was logged in with a deleted google account. This guide should say first remove all google accounts and remove screen locks, so it’s only swipe or no security; otherwise you are asked for security at startup. But for me, I can’t do anything about it since the account that was on the phone is now deleted.
Non, je ne pas reçu mon téléphone Samsung Galaxy A5 s'arrête au niveau où ,on écrit CUSTOM BINARY BLOCKED BY FRP LOCK
it is asking for a google acount.. help s
I reset it after I lent it to my nephew and now it is saying I need to sign in using the last google account on here but I have no idea what it is, I’m locked out of my own phone
Went to do factory at the bottom of the screen it says failed to open recovery_cause(no such file or directory)
Reboot Recovery Cause (unknown)
I selected factory reset, and that ran These messages came up at the bottom
Wipping data
formatting data
Data wipe complete
E:Failed to clear BCB message: failed to find/misc partition
I did a reboot, and following message came up
An unauthorised attempt has been made to do a factory reset, then it asks for the last google account, but we do not have those details..... so what now?
For above, it is a Galaxy A520F
Cela a été ma seule solution pour réinitialiser le téléphone.
Impossible de le faire via les raccourcis habituels.
Merci beaucoup 👍👍
122 farklı kişi bu kılavuzu tamamladı.
36 Yorum
Hey i did the second part because i couldn't open my phone everytime it says all apps stop working and even the system process stopped, i shut down my phone then pressed up volume, power and home button but i couldn't see anything its just all black
I did all of this and now my phone just keeps rebooting and saying Samsung galaxy a5 powered by android and that's all
I have the same problem - any solution?
I have the same problem and press power button ,just it
the problem is, i bought it from friend on social app. and he forgot the gmail password, and this phone stuck with me. not working.
i do this all but my display not work only blank black
hoelang duurd dit
hoelang duurd reboot system now dit
iknheb laasre foto al een half uur eropstaan
how long will thiss take , the last foto , is about 15 min ago
y still have the green stripe last foto 15 min now
It's reset but now it's asking for google account thing and I've forgotten the password?
When i reset..screen off but never trun on...
And now audio notification only....plz help me.
I have reset and now the phone is stuck in the glowing of the samsung logo. Pls help
Did you ever figure this out? I’ve just done it and have the same result as you two years ago.
adiboo -
Just hold in the power button and release. I had to hold mine for a few seconds, then the second time I just pushed it quickly … could have been either time, but either way, it worked… after being stuck on the Samsung screen for almost an hour.
how can i hard reset my a5 if i dont know my pattern and my home button is broken ?????????
i have reset and now the phone is stuck in glowing in sky blue color and appearing product name , current binaay, system status and all??plz help
I work at a cell phone place. I had a customer locked out of his phone because he forgot the pattern. Holding volume up, power, and home button didn’t do anything at all. Holding volume down, power and home button brought it to a custom OS screen that could potentially ruin your phone. But the key is to get it to the Samsung logo startup screen in any way possible.
I got to the custom OS screen using the Volume Down, power and home
Then I hit volume down to cancel which leads it to the Samsung startup screen.
This is the important part. there’s a brief second where the screen goes black before the Samsung logo appears. while the screen is completely black, hold down the Volume Up, Power, and Home button. When the Samsung Galaxy A5 words all appear on the screen, let go of the power button but keep the other 2 pressed down. This leads to the factory reset menu and the rest you know already :)
tryed to reset and did not work even my old gmail locked me out what a phone it sucks big time thk god it coverd by warranty michelle nov 2
How can I do that with my sumsung A6+ because I followed the steps but it says no data connection and I just forgot my unlock code. Help please
How to fix my sumsung A6+ if I forgot my
Thanks a lot brother
Tried this and is saying unauthorized factory reset was attempted so sign in to wifi and to your Google account which I can't remember password also won't let me sign into wifi cause it says unauthorized factory reset was applied and can't bring up sign in what do I do
Bonjour,
J’ai essayé d’effectuer la manipulation mais il ne se passe rien. Suite à une petite chute (quelques centimètres), l’écran de mon smartphone est tout noir.
Comment puis-je faire pour le réinitialiser ?
URGENT! URGENT! URGENT!
Le téléchargement est très long; j’en suis à 15 minutes et ce n’est pas fini!!!
Bonjour j’ai essayé comme expliquer dans ton tuto nickel sauf que la plus moyen de Faire quoi que ce soit avec le téléphone est-ce que tu peux m’aider s’il te plaît merci
Merci et bravo. J’ai suivi à la lettre les instructions et j’ai réussi à réinitialiser mon téléphone. Tout fonctionne. Je suis super contente. Merci encore.
I tried this but didn't work
Thank you… THANK YOU!!! Had two A5s to reset and sell but hit a brick wall on my wife's phone and couldn't do anything without going in loops. The hard reset worked.
eidolon 58 - Yanıt
I need to reset the phone because I've forgotten my password to unlock the phone after it's had an update. Unfortunately, I can't turn the phone off without the password so I'm stuck in limbo - do you have any suggestions?
sandra.shaw90.ss - Yanıt
SAMSUNG A5 2017 : dernière mise à jour 1er février 2021. Le 20 mars 2023, ma banque en ligne m'informe que je ne pourrai bientôt plus me connecter à défaut de mise à jour, pour des questions de sécurité. Impossible de mettre à jour, ces mises à jour n'existent plus ! Près de 400 euros le téléphone. On nous prend vraiment pour des demeurés. Nos politiques courageux s'empresseront-ils de modifier les lois ?
NICOLE C. - Yanıt
