Ana içeriğe geç
Giriş
This guide will explain the process of restarting the HTC myTouch 3G after an Operating System crash.
  1. Start by turning off the phone. Hold the Home and End keys for ten to thirty seconds, or until the home recovery display appears. Hold the Home and End keys for ten to thirty seconds, or until the home recovery display appears.
    • Start by turning off the phone.
    • Hold the Home and End keys for ten to thirty seconds, or until the home recovery display appears.
  2. Press the Home and End button once again to open the Recovery Options menu. Press the Home and End button once again to open the Recovery Options menu.
    • Press the Home and End button once again to open the Recovery Options menu.
  3. Using the trackball, scroll to and select "wipe data/factory reset". Using the trackball, scroll to and select "wipe data/factory reset".
    • Using the trackball, scroll to and select "wipe data/factory reset".
  4. Once the reset is complete, scroll back to "reboot system now". Once the reset is complete, scroll back to "reboot system now".
    • Once the reset is complete, scroll back to "reboot system now".
Sonuç
Warning: This process will wipe out any data on the phone.
8 farklı kişi bu kılavuzu tamamladı.
Erik
84 İtibar
2 adet Kılavuz yazıldı
Takım
Cal Poly, Team 2-9, Propen Fall 2012 Cal Poly, Team 2-9, Propen Fall 2012 üyesi
CPSU-PROPEN-F12S2G9
3 Üyeler
5 adet Kılavuz yazıldı
3 Yorum
this guide is soo good but my only problem is dat de scroll key is able to scroll through de options at the recovery page but unable to select. how do i select the "wipe data/factory reset option
David Mensah - Yanıt
i have the same problem, can you have a solution?
Raúl Torres Cázares -
Muchas gracias me ha servido mucho hace tiempo no trataba con estas reliquias que fueron la antesala de los equipos android de ahora
migueldan7 - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 Gün: 5
Son 30 Gün: 17
Her zaman: 22,079
