Ana içeriğe geç
How to Hem a Skirt
Neye ihtiyacın var
  1. How to Hem a Skirt, How to Hem a Skirt: adım 1, 1 resimden 1.
    • Turn the garment inside out.
    • Inspect the hem: Are there any bulky regions along the hem or is it even all across? Is the hem straight or does it have curves?
  2. How to Hem a Skirt: adım 2, 1 resimden 1.
    • If your skirt has an existing hem, use seam ripper to remove current hem.
    • Place the pointed end in each stitch and cut it using the blade edge on the seam ripper.
    • Be sure not to rip the actual garment.
    • The example skirt did not have an existing hem.
  3. How to Hem a Skirt: adım 3, 3 resimden 1. How to Hem a Skirt: adım 3, 3 resimden 2. How to Hem a Skirt: adım 3, 3 resimden 3.
    • If the skirt is being shortened, wear the skirt inside out and measure the desired length.
    • Use sewing chalk to mark the length.
    • Pin up the fabric along the desired chalk line.
    • If you are only adding a hem, measure and fold 1/2 an inch up from the bottom of the skirt and pin along the edge.
    • You want to wear the skirt inside out so the hem is not on the outside of the skirt.
    • It may help to have a partner mark the desired length of the skirt while you are wearing it.
  4. How to Hem a Skirt: adım 4, 3 resimden 1. How to Hem a Skirt: adım 4, 3 resimden 2. How to Hem a Skirt: adım 4, 3 resimden 3.
    • Thread the needle with matching thread.
    • Start with a Backstitch to secure the thread.
    • Stitch along the hem, avoiding the pins.
    • Create a backstitch once you meet the place where you began.
    • For the example images, a darker thread was used for better visibility.
  5. How to Hem a Skirt: adım 5, 2 resimden 1. How to Hem a Skirt: adım 5, 2 resimden 2.
    • Cut the thread to detach from needle.
    • Cut any excess thread.
  6. How to Hem a Skirt: adım 6, 1 resimden 1.
    • Turn the skirt right side out.
    • Inspect the hem to ensure there are no gaps.
    • Try on skirt for fit.
Bitiş Çizgisi
Bir başkası bu kılavuzu tamamladı.
Safiah Nemr
157 İtibar
1 Kılavuz yazıldı
Ekip
UC Davis, Team 1-3, Andersen Winter 2024 UC Davis, Team 1-3, Andersen Winter 2024 üyesi
UCD-ANDERSEN-W24S1G3
3 Üyeler
2 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 22
Her zaman: 265
