Ana içeriğe geç
How to Hook up Front Panel Connectors to an ATX Motherboard
Neye ihtiyacın var
    1. How to Hook up Front Panel Connectors to an ATX Motherboard, How to Hook up Front Panel Connectors to an ATX Motherboard: adım 1, 3 resimden 1. How to Hook up Front Panel Connectors to an ATX Motherboard, How to Hook up Front Panel Connectors to an ATX Motherboard: adım 1, 3 resimden 2. How to Hook up Front Panel Connectors to an ATX Motherboard, How to Hook up Front Panel Connectors to an ATX Motherboard: adım 1, 3 resimden 3.
      • Lay your PC on its side and unscrew the side panel thumb screws. (Open your PC case)
      • For some computer cases you may need a screw driver to remove actual screws.
      FixBot'a Sor
      Yorum Ekle
    2. How to Hook up Front Panel Connectors to an ATX Motherboard: adım 2, 2 resimden 1. How to Hook up Front Panel Connectors to an ATX Motherboard: adım 2, 2 resimden 2.
      • Once the screws are removed lift off the side panel to expose the motherboard and internal cables.
      • Locate where the front panel pins are.
      FixBot'a Sor
      Yorum Ekle
    3. How to Hook up Front Panel Connectors to an ATX Motherboard: adım 3, 3 resimden 1. How to Hook up Front Panel Connectors to an ATX Motherboard: adım 3, 3 resimden 2. How to Hook up Front Panel Connectors to an ATX Motherboard: adım 3, 3 resimden 3.
      • Plug the cable marked Reset SW into the motherboard. This will allow your reset button to actually work.
      FixBot'a Sor
      Yorum Ekle
    4. How to Hook up Front Panel Connectors to an ATX Motherboard: adım 4, 3 resimden 1. How to Hook up Front Panel Connectors to an ATX Motherboard: adım 4, 3 resimden 2. How to Hook up Front Panel Connectors to an ATX Motherboard: adım 4, 3 resimden 3.
      • Plug the Power SW cable in above the Reset SW on the motherboard. This will allow you to turn on your computer with the power button on the front of your PC case.
      FixBot'a Sor
      Yorum Ekle
    5. How to Hook up Front Panel Connectors to an ATX Motherboard: adım 5, 3 resimden 1. How to Hook up Front Panel Connectors to an ATX Motherboard: adım 5, 3 resimden 2. How to Hook up Front Panel Connectors to an ATX Motherboard: adım 5, 3 resimden 3.
      • Plug the Power Led + into the top left prong. Positive goes on the left prong.
      FixBot'a Sor
      Yorum Ekle
    6. How to Hook up Front Panel Connectors to an ATX Motherboard: adım 6, 3 resimden 1. How to Hook up Front Panel Connectors to an ATX Motherboard: adım 6, 3 resimden 2. How to Hook up Front Panel Connectors to an ATX Motherboard: adım 6, 3 resimden 3.
      • Connect the Power Led - cable to the prong on the right.
      • This is the final cable structure.
      FixBot'a Sor
      Yorum Ekle
    7. How to Hook up Front Panel Connectors to an ATX Motherboard: adım 7, 1 resimden 1.
      • Power LED
      • Power Switch
      • Reset Switch
      FixBot'a Sor
      Yorum Ekle
Sonuç
To reassemble your device, follow the instructions, steps 1 and 2, in reverse order.
11 farklı kişi bu kılavuzu tamamladı.
Nathan Carini
357 İtibar
1 Kılavuz yazıldı
Ekip
2Kılavuz Yorumları
Petite précision :
Les broches sur lesquels il faut brancher les connecteurs des différents éléments du boitier sont indiquées dans la notice de la carte mère (button power, LEDs, etc.). L’emplacement et l’ordre de branchement des différents éléments du boitier est susceptible de varier selon le modèle de la carte mère.
Cela concerne aussi le buzzer si vous en avez un.
Brendan - Yanıt Paylaş
Bonjour Tout le monde*
Je suis d'accord avec vous , mais dans quel sens mettre sur le boitier de démarrage vous avez power reset led 2 prise usb , quand j'ai enlevé du boitier je n'ai marquer les metttre ou
Je vous remercie d'avance.
KIEFFER RENE - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 32
Son 7 gün: 234
Son 30 gün: 969
Her zaman: 144,503
