Ana içeriğe geç
How to Install Handlebar Tape
Neye ihtiyacın var
  1. How to Install Handlebar Tape, How to Install Handlebar Tape: adım 1, 2 resimden 1. How to Install Handlebar Tape, How to Install Handlebar Tape: adım 1, 2 resimden 2.
    • Flip the hood of the brake lever upwards.
  2. How to Install Handlebar Tape: adım 2, 3 resimden 1. How to Install Handlebar Tape: adım 2, 3 resimden 2. How to Install Handlebar Tape: adım 2, 3 resimden 3.
    • Peel off the adhesive covering from the back of the bar tape.
    • Place one end of the bar tape around the handlebar, making sure to leave a half inch extended past the end of the handlebar.
    • Begin tightly wrapping the bar tape clockwise around the handlebar so that the bar tape overlaps itself slightly.
  3. How to Install Handlebar Tape: adım 3, 2 resimden 1. How to Install Handlebar Tape: adım 3, 2 resimden 2.
    • After a few wraps, tuck the extra bar tape into the end of the handlebar and firmly push in the bar end plug.
  4. How to Install Handlebar Tape: adım 4, 2 resimden 1. How to Install Handlebar Tape: adım 4, 2 resimden 2.
    • Continue to tightly wrap the bar tape around the bar as evenly as possible.
    • Make sure the adhesive on the back of the bar tape is making contact with the metal handlebar.
  5. How to Install Handlebar Tape: adım 5, 3 resimden 1. How to Install Handlebar Tape: adım 5, 3 resimden 2. How to Install Handlebar Tape: adım 5, 3 resimden 3.
    • Take the extra piece of bar tape provided and cut it to fit the back of the brake lever.
  6. How to Install Handlebar Tape: adım 6, 3 resimden 1. How to Install Handlebar Tape: adım 6, 3 resimden 2. How to Install Handlebar Tape: adım 6, 3 resimden 3.
    • Continue wrapping over lever.
    • Keep in mind the tightness and evenness of space between each wrap as you continue.
  7. How to Install Handlebar Tape: adım 7, 2 resimden 1. How to Install Handlebar Tape: adım 7, 2 resimden 2.
    • Flip the break lever hood back down and continue.
  8. How to Install Handlebar Tape: adım 8, 2 resimden 1. How to Install Handlebar Tape: adım 8, 2 resimden 2.
    • Stop wrapping about 2 inches from stem.
  9. How to Install Handlebar Tape: adım 9, 3 resimden 1. How to Install Handlebar Tape: adım 9, 3 resimden 2. How to Install Handlebar Tape: adım 9, 3 resimden 3.
    • Cut the bar tape diagonally at an approximately 60 degree angle.
  10. How to Install Handlebar Tape: adım 10, 1 resimden 1.
    • Finish the wrap.
    • The cut should make the end of the bar tape a straight line.
  11. How to Install Handlebar Tape: adım 11, 3 resimden 1. How to Install Handlebar Tape: adım 11, 3 resimden 2. How to Install Handlebar Tape: adım 11, 3 resimden 3.
    • Use the electrical tape provided to tightly secure the end of the wrap.
  12. How to Install Handlebar Tape: adım 12, 3 resimden 1. How to Install Handlebar Tape: adım 12, 3 resimden 2. How to Install Handlebar Tape: adım 12, 3 resimden 3.
    • Press down on electrical tape to secure it.
  13. How to Install Handlebar Tape: adım 13, 3 resimden 1. How to Install Handlebar Tape: adım 13, 3 resimden 2. How to Install Handlebar Tape: adım 13, 3 resimden 3.
    • Repeat steps 1-12 on the other side, now wrapping counterclockwise.
Bitiş Çizgisi
Bir başkası bu kılavuzu tamamladı.
Elizabeth Hall
131 İtibar
1 Kılavuz yazıldı
Ekip
UC Davis, Team S2-G7, Cole Spring 2017 UC Davis, Team S2-G7, Cole Spring 2017 üyesi
UCD-COLE-S17S2G7
3 Üyeler
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 22
Her zaman: 4,112
