Ana içeriğe geç
How to Install Handlebar Tape
Neye ihtiyacın var
    1. How to Install Handlebar Tape, How to Install Handlebar Tape: adım 1, 2 resimden 1. How to Install Handlebar Tape, How to Install Handlebar Tape: adım 1, 2 resimden 2.
      • Flip the hood of the brake lever upwards.
      FixBot'a Sor
      Yorum Ekle
    2. How to Install Handlebar Tape: adım 2, 3 resimden 1. How to Install Handlebar Tape: adım 2, 3 resimden 2. How to Install Handlebar Tape: adım 2, 3 resimden 3.
      • Peel off the adhesive covering from the back of the bar tape.
      • Place one end of the bar tape around the handlebar, making sure to leave a half inch extended past the end of the handlebar.
      • Begin tightly wrapping the bar tape clockwise around the handlebar so that the bar tape overlaps itself slightly.
      FixBot'a Sor
      Yorum Ekle
    3. How to Install Handlebar Tape: adım 3, 2 resimden 1. How to Install Handlebar Tape: adım 3, 2 resimden 2.
      • After a few wraps, tuck the extra bar tape into the end of the handlebar and firmly push in the bar end plug.
      FixBot'a Sor
      Yorum Ekle
    4. How to Install Handlebar Tape: adım 4, 2 resimden 1. How to Install Handlebar Tape: adım 4, 2 resimden 2.
      • Continue to tightly wrap the bar tape around the bar as evenly as possible.
      • Make sure the adhesive on the back of the bar tape is making contact with the metal handlebar.
      FixBot'a Sor
      Yorum Ekle
    5. How to Install Handlebar Tape: adım 5, 3 resimden 1. How to Install Handlebar Tape: adım 5, 3 resimden 2. How to Install Handlebar Tape: adım 5, 3 resimden 3.
      • Take the extra piece of bar tape provided and cut it to fit the back of the brake lever.
      FixBot'a Sor
      Yorum Ekle
    6. How to Install Handlebar Tape: adım 6, 3 resimden 1. How to Install Handlebar Tape: adım 6, 3 resimden 2. How to Install Handlebar Tape: adım 6, 3 resimden 3.
      • Continue wrapping over lever.
      • Keep in mind the tightness and evenness of space between each wrap as you continue.
      FixBot'a Sor
      Yorum Ekle
    7. How to Install Handlebar Tape: adım 7, 2 resimden 1. How to Install Handlebar Tape: adım 7, 2 resimden 2.
      • Flip the break lever hood back down and continue.
      FixBot'a Sor
      Yorum Ekle
    8. How to Install Handlebar Tape: adım 8, 2 resimden 1. How to Install Handlebar Tape: adım 8, 2 resimden 2.
      • Stop wrapping about 2 inches from stem.
      FixBot'a Sor
      Yorum Ekle
    9. How to Install Handlebar Tape: adım 9, 3 resimden 1. How to Install Handlebar Tape: adım 9, 3 resimden 2. How to Install Handlebar Tape: adım 9, 3 resimden 3.
      • Cut the bar tape diagonally at an approximately 60 degree angle.
      FixBot'a Sor
      Yorum Ekle
    10. How to Install Handlebar Tape: adım 10, 1 resimden 1.
      • Finish the wrap.
      • The cut should make the end of the bar tape a straight line.
      FixBot'a Sor
      Yorum Ekle
    11. How to Install Handlebar Tape: adım 11, 3 resimden 1. How to Install Handlebar Tape: adım 11, 3 resimden 2. How to Install Handlebar Tape: adım 11, 3 resimden 3.
      • Use the electrical tape provided to tightly secure the end of the wrap.
      FixBot'a Sor
      Yorum Ekle
    12. How to Install Handlebar Tape: adım 12, 3 resimden 1. How to Install Handlebar Tape: adım 12, 3 resimden 2. How to Install Handlebar Tape: adım 12, 3 resimden 3.
      • Press down on electrical tape to secure it.
      FixBot'a Sor
      Yorum Ekle
    13. How to Install Handlebar Tape: adım 13, 3 resimden 1. How to Install Handlebar Tape: adım 13, 3 resimden 2. How to Install Handlebar Tape: adım 13, 3 resimden 3.
      • Repeat steps 1-12 on the other side, now wrapping counterclockwise.
      FixBot'a Sor
      Yorum Ekle
Bitiş Çizgisi
Bir başkası bu kılavuzu tamamladı.
Elizabeth Hall
137 İtibar
1 Kılavuz yazıldı
Ekip
UC Davis, Team S2-G7, Cole Spring 2017 UC Davis, Team S2-G7, Cole Spring 2017 üyesi
UCD-COLE-S17S2G7
3 Üyeler
11 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 15
Son 30 gün: 45
Her zaman: 4,641
