Ana içeriğe geç
How to Install LED License Plate Lights
Neye ihtiyacın var
  1. How to Install LED License Plate Lights, Prep work: adım 1, 1 resimden 1.
    • You can choose to raise your car with a car lift jack to get better access to the license plate area. This is not absolutely necessary, but will make installation easier.
    FixBot'a Sor
    Yorum Ekle
  2. How to Install LED License Plate Lights, Removing the stock bulb: adım 2, 3 resimden 1. How to Install LED License Plate Lights, Removing the stock bulb: adım 2, 3 resimden 2. How to Install LED License Plate Lights, Removing the stock bulb: adım 2, 3 resimden 3.
    • Pull out the license plate lamp assembly and remove the stock license plate bulb.
    FixBot'a Sor
    Yorum Ekle
  3. How to Install LED License Plate Lights, Installing the LED license plate bulb: adım 3, 2 resimden 1. How to Install LED License Plate Lights, Installing the LED license plate bulb: adım 3, 2 resimden 2.
    • Install back the new LED license plate bulb.
    • Test to make sure the LED bulb works.
    FixBot'a Sor
    Yorum Ekle
  4. How to Install LED License Plate Lights, Putting the license plate assembly back: adım 4, 2 resimden 1. How to Install LED License Plate Lights, Putting the license plate assembly back: adım 4, 2 resimden 2.
    • Put the license plate assembly back and repeat on the other side.
    FixBot'a Sor
    Yorum Ekle
  5. How to Install LED License Plate Lights, Enjoy: adım 5, 1 resimden 1.
    • Once everything works, you can enjoy your new LED license plate look.
    FixBot'a Sor
    Yorum Ekle
Sonuç
See how easy installing these LED license plate lights are? It's almost unbelievable how a quick and simple installation could make such a difference.
6 farklı kişi bu kılavuzu tamamladı.
Eric Wu
3.600 İtibar
23 adet Kılavuz yazıldı
2Kılavuz Yorumları
Why do all your pics have such obnoxious watermarks? If the pics are specifically for iFixit.com I would remove the watermarks.
David Spalding - Yanıt Paylaş
Good information!
limoh - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 25
Son 30 gün: 156
Her zaman: 17,459
