Ana içeriğe geç
How to Install a 2.5" SSD Into a Silicone Enclosure
  1. How to Install a 2.5" SSD Into a Silicone Enclosure, Insert the SSD into the enclosure: adım 1, 2 resimden 1. How to Install a 2.5" SSD Into a Silicone Enclosure, Insert the SSD into the enclosure: adım 1, 2 resimden 2.
    • Before you insert the new hard drive, note the orientation of the SATA connectors embedded in the enclosure:
    • The wide power SATA port
    • The narrower data SATA port
  2. How to Install a 2.5" SSD Into a Silicone Enclosure: adım 2, 3 resimden 1. How to Install a 2.5" SSD Into a Silicone Enclosure: adım 2, 3 resimden 2. How to Install a 2.5" SSD Into a Silicone Enclosure: adım 2, 3 resimden 3.
    • Using the previous step, orient the new drive so that its SATA connectors will align with the enclosure's.
    • Slide the drive into the enclosure's opening.
    • Push the drive into the enclosure until it stops sliding and the SATA connectors are completely seated.
  3. How to Install a 2.5" SSD Into a Silicone Enclosure: adım 3, 3 resimden 1. How to Install a 2.5" SSD Into a Silicone Enclosure: adım 3, 3 resimden 2. How to Install a 2.5" SSD Into a Silicone Enclosure: adım 3, 3 resimden 3.
    • Stretch the remaining enclosure corners over the drive so that the silicone cover encapsulates the drive.
Sonuç
Your drive is ready to be used!
3 farklı kişi bu kılavuzu tamamladı.
Arthur Shi
281.866 İtibar
585 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
118 Üyeler
19.418 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 15
Son 30 gün: 23
Her zaman: 1,702
