Ana içeriğe geç
How to Install a Fifth String Shubb Banjo Capo
Neye ihtiyacın var
  1. How to Install a Fifth String Shubb Banjo Capo, How to Install a Fifth String Shubb Banjo Capo: adım 1, 3 resimden 1. How to Install a Fifth String Shubb Banjo Capo, How to Install a Fifth String Shubb Banjo Capo: adım 1, 3 resimden 2. How to Install a Fifth String Shubb Banjo Capo, How to Install a Fifth String Shubb Banjo Capo: adım 1, 3 resimden 3.
    • Line the capo up along the fifth string side of the fretboard as shown.
    • Line the capo screw holes up about 12 mm from the fifth fret bar and about 4 mm from the face of the fret.
    • Be careful not to line the capo screw holes up directly below a fret bar or directly on top of a fret marker.
  2. How to Install a Fifth String Shubb Banjo Capo: adım 2, 1 resimden 1.
    • Use the marker to mark where the screws should go.
  3. How to Install a Fifth String Shubb Banjo Capo: adım 3, 1 resimden 1.
    • Use the drill to drill both holes for the two screws.
    • The holes should be drilled about 1 cm deep
    • You may need to borrow an extra pair of hands to help you stabilize the banjo while you perform this step.
  4. How to Install a Fifth String Shubb Banjo Capo: adım 4, 2 resimden 1. How to Install a Fifth String Shubb Banjo Capo: adım 4, 2 resimden 2.
    • Use the flat head screw driver to insert and tighten the screws.
  5. How to Install a Fifth String Shubb Banjo Capo: adım 5, 3 resimden 1. How to Install a Fifth String Shubb Banjo Capo: adım 5, 3 resimden 2. How to Install a Fifth String Shubb Banjo Capo: adım 5, 3 resimden 3.
    • To use the capo, slide the capo finger down to the desired fret.
    • Then, tighten the spring knob.
Sonuç
For more information check out the Shubb fifth string capo website at: http://www.shubb.com/fs/index.html
6 farklı kişi bu kılavuzu tamamladı.
Sara Wier
263 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 23-4, Green Winter 2015 Cal Poly, Team 23-4, Green Winter 2015 üyesi
CPSU-GREEN-W15S23G4
7 Üyeler
15 adet Kılavuz yazıldı
1Rehber Yorum
thank you. Now, I know how to do and i décide to buy a shubb and to install it
Jean-Denis Del - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 36
Her zaman: 7,878
