Ana içeriğe geç
How to Install a Hard Drive Sled Adapter for Mac Pro First Generation
Neye ihtiyacın var
  1. How to Install a Hard Drive Sled Adapter for Mac Pro First Generation, Case Panel: adım 1, 1 resimden 1.
    • Lift the lever to unlock the case.
  2. How to Install a Hard Drive Sled Adapter for Mac Pro First Generation: adım 2, 1 resimden 1.
    Bu adımda kullanılan alet:
    Anti-Static Wrist Strap
    $7.95
    Satın Al
    • Remove the side panel of the Mac Pro.
    • Discharge any static electricity by touching a grounded surface prior to working on any internal components. Touching the metal PCI slot covers works great, or any other grounded metal surface. You can also wear a anti-static wrist strap.
  3. How to Install a Hard Drive Sled Adapter for Mac Pro First Generation, Locate the Hard Drive Bays: adım 3, 1 resimden 1.
    • Locate the desired hard drive bay after opening the case .
    • This is usually the drive closest to the front of the case.
  4. How to Install a Hard Drive Sled Adapter for Mac Pro First Generation, Remove the Hard Drive Bay: adım 4, 3 resimden 1. How to Install a Hard Drive Sled Adapter for Mac Pro First Generation, Remove the Hard Drive Bay: adım 4, 3 resimden 2. How to Install a Hard Drive Sled Adapter for Mac Pro First Generation, Remove the Hard Drive Bay: adım 4, 3 resimden 3.
    • Make sure that the clip used to release the side panel is open or the Hard Drive bays won't slide out
    • Pull the Hard Drive straight out by grabbing the metal sled from the bottom. It may be hard to pull out at first, but after it gets released the sled shouldn't take a lot of effort to remove.
  5. How to Install a Hard Drive Sled Adapter for Mac Pro First Generation, Remove metal Hard Drive sled: adım 5, 3 resimden 1. How to Install a Hard Drive Sled Adapter for Mac Pro First Generation, Remove metal Hard Drive sled: adım 5, 3 resimden 2. How to Install a Hard Drive Sled Adapter for Mac Pro First Generation, Remove metal Hard Drive sled: adım 5, 3 resimden 3.
    • When handling the hard drive hold it by the sled or sides be sure not to touch the green circuit board visible in all 3 pictures.
    • Locate the four 6-32 type screws on the Hard Drive sled.
    • Using a Phillips head screw driver remove the four screws and separate the metal sled from the Hard Drive
  6. How to Install a Hard Drive Sled Adapter for Mac Pro First Generation, How to Install a Hard Drive Sled Adapter for Mac Pro First Generation: adım 6, 3 resimden 1. How to Install a Hard Drive Sled Adapter for Mac Pro First Generation, How to Install a Hard Drive Sled Adapter for Mac Pro First Generation: adım 6, 3 resimden 2. How to Install a Hard Drive Sled Adapter for Mac Pro First Generation, How to Install a Hard Drive Sled Adapter for Mac Pro First Generation: adım 6, 3 resimden 3.
    • Insert the two tabs on the left side of the metal adapter bracket into the slots on the left side of the hard drive bay sled.
    • Align the holes on the right side.
  7. How to Install a Hard Drive Sled Adapter for Mac Pro First Generation: adım 7, 1 resimden 1.
    • Screw the two 7.8mm PH0 screws into the two holes on the right.
    • Leave these screws slightly loose; they will be tightened once the hard drive is attached.
  8. How to Install a Hard Drive Sled Adapter for Mac Pro First Generation: adım 8, 3 resimden 1. How to Install a Hard Drive Sled Adapter for Mac Pro First Generation: adım 8, 3 resimden 2. How to Install a Hard Drive Sled Adapter for Mac Pro First Generation: adım 8, 3 resimden 3.
    • Align the holes in the hard drive with the three holes on the bracket.
    • Screw the three 6.1mm PH0 screws into the bracket and hard drive.
    • These screws can be secured tightly.
  9. How to Install a Hard Drive Sled Adapter for Mac Pro First Generation: adım 9, 1 resimden 1.
    • Tighten the two 7.8mm PH0 screws on the right side of the bracket.
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Kristen Gismondi
81.663 İtibar
200 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
135 Üyeler
16.732 adet Kılavuz yazıldı
Bir Yorum
Tried installing these on MacPro5,1 today. Very disappointed. Sled does not slide into place correctly, and any attempt to nudge it into place only scratches the carrier.
Going back to OWC sled to mount SSD drives.
tjod - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 15
Her zaman: 5,770
