Ana içeriğe geç
How to Install a New Battery in Your Google Pixel 8 Pro
Neye ihtiyacın var
  1. How to Install a New Battery in Your Google Pixel 8 Pro, Remove the old adhesive from the frame: adım 1, 3 resimden 1. How to Install a New Battery in Your Google Pixel 8 Pro, Remove the old adhesive from the frame: adım 1, 3 resimden 2. How to Install a New Battery in Your Google Pixel 8 Pro, Remove the old adhesive from the frame: adım 1, 3 resimden 3.
    Bu adımda kullanılan alet:
    Satın Al
    • In order for the battery to properly adhere, you must remove all the old adhesive and its residue.
    • Use the flat end of a spudger to scrape up and remove all the old adhesive from the frame.
    • If you're having trouble, apply a few drops of highly-concentrated (greater than 90%) isopropyl alcohol to the adhesive and scrape it up.
    • Use your fingers or tweezers to pick off big chunks.
  2. How to Install a New Battery in Your Google Pixel 8 Pro, Remove the old adhesive residue: adım 2, 1 resimden 1.
    Microfiber Cleaning Cloths
    $3.99
    Satın Al
    • Once you've removed all the old adhesive, apply a few drops of highly-concentrated (greater than 90%) isopropyl alcohol to any residue left on the frame and wipe it away with a microfiber or lint-free cloth.
  3. How to Install a New Battery in Your Google Pixel 8 Pro, Temporarily reconnect the battery: adım 3, 2 resimden 1. How to Install a New Battery in Your Google Pixel 8 Pro, Temporarily reconnect the battery: adım 3, 2 resimden 2.
    • Lay the battery in its recess and temporarily reconnect it to the logic board to check its fit and cable length before adhering it.
    • Once you've found the proper alignment, disconnect the battery and remove it.
  4. How to Install a New Battery in Your Google Pixel 8 Pro, Install the battery: adım 4, 3 resimden 1. How to Install a New Battery in Your Google Pixel 8 Pro, Install the battery: adım 4, 3 resimden 2. How to Install a New Battery in Your Google Pixel 8 Pro, Install the battery: adım 4, 3 resimden 3.
    Tesa 61395 Tape
    $5.99
    Satın Al
    • If your battery comes with adhesive pre-installed, remove the plastic liner and firmly press the battery into its recess to secure it with the adhesive.
    • If your battery doesn't have pre-installed adhesive, apply strips of double-sided tape such as Tesa Tape where the old adhesive was and firmly press the battery into its recess to secure it.
Sonuç
Spencer Day
58.593 İtibar
430 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
137 Üyeler
17.523 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 18
Son 30 gün: 63
Her zaman: 565
