Ana içeriğe geç
How to Install and Remove Tiles
Neye ihtiyacın var
  1. How to Install and Remove Tiles, Remove the Front Panel: adım 1, 3 resimden 1. How to Install and Remove Tiles, Remove the Front Panel: adım 1, 3 resimden 2. How to Install and Remove Tiles, Remove the Front Panel: adım 1, 3 resimden 3.
    • Use your fingers to pull the Front Panel off the magnets securing it to the chassis.
  2. How to Install and Remove Tiles, Remove the Tiles: adım 2, 3 resimden 1. How to Install and Remove Tiles, Remove the Tiles: adım 2, 3 resimden 2. How to Install and Remove Tiles, Remove the Tiles: adım 2, 3 resimden 3.
    • Use your fingers to push the bottom of the Tile up and off the front panel and release its clips.
    • Remove the Tile.
  3. How to Install and Remove Tiles: adım 3, 3 resimden 1. How to Install and Remove Tiles: adım 3, 3 resimden 2. How to Install and Remove Tiles: adım 3, 3 resimden 3.
    • Repeat this procedure for the remaining tiles.
  4. How to Install and Remove Tiles, Install the Tiles: adım 4, 3 resimden 1. How to Install and Remove Tiles, Install the Tiles: adım 4, 3 resimden 2. How to Install and Remove Tiles, Install the Tiles: adım 4, 3 resimden 3.
    • Tiles can be installed in any orientation, even the ones with graphics.
    • Lay a Tile over an open slot on your Front Panel.
    • Use your fingers to press the tile into the slot and engage the clips.
    • You'll hear and feel an audible "click" when the clips engage.
  5. How to Install and Remove Tiles: adım 5, 3 resimden 1. How to Install and Remove Tiles: adım 5, 3 resimden 2. How to Install and Remove Tiles: adım 5, 3 resimden 3.
    • Install the remaining Tiles.
  6. How to Install and Remove Tiles: adım 6, 3 resimden 1. How to Install and Remove Tiles: adım 6, 3 resimden 2. How to Install and Remove Tiles: adım 6, 3 resimden 3.
    • Lay the bottom of the Front Panel on the small, protruding lip in the silver base to align its tabs.
    • Press the Front Panel flat to the chassis and let it align to the magnets.
Sonuç
If you need help, contact Framework support.
Alex Diaz-Kokaisl
213.178 İtibar
1.040 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 14
Her zaman: 180
