Ana içeriğe geç
How to Install macOS High Sierra
Neye ihtiyacın var
  1. How to Install macOS High Sierra, How to Install macOS High Sierra: adım 1, 2 resimden 1. How to Install macOS High Sierra, How to Install macOS High Sierra: adım 1, 2 resimden 2.
    • With the device powered off, disconnect any external hard drives and flash drives.
    • Plug in your macOS High Sierra bootable flash drive.
    • Hold down the [option] or [alt] (⌥) key on the keyboard and power on the device.
    • When you see the boot selection screen as shown, release the [option] key.
    • Use either the keyboard's arrow keys or the mouse to select "Install MacOS High Sierra." Press [enter] or click your selection with the mouse.
    FixBot'a Sor
    Yorum Ekle
  2. How to Install macOS High Sierra: adım 2, 2 resimden 1. How to Install macOS High Sierra: adım 2, 2 resimden 2.
    • Your Mac will begin copying the installation files from the flash drive. This may take up to 30 minutes.
    • Depending on the speed of your flash drive, it may look like progress has frozen, but it should resume if you continue to wait.
    • When prompted, select your language and press [enter], or click the arrow button.
    FixBot'a Sor
    Yorum Ekle
  3. How to Install macOS High Sierra: adım 3, 2 resimden 1. How to Install macOS High Sierra: adım 3, 2 resimden 2.
    • If you don't need to pre-configure your hard drive, skip to step 5. If you're not sure or if the drive is used, it's a good idea to pre-configure your hard drive.
    • Select "Disk Utility" from the menu and press [enter] or click the continue button.
    FixBot'a Sor
    Yorum Ekle
  4. How to Install macOS High Sierra: adım 4, 3 resimden 1. How to Install macOS High Sierra: adım 4, 3 resimden 2. How to Install macOS High Sierra: adım 4, 3 resimden 3.
    • Select your hard drive from the left column in Disk Utility.
    • It is most likely the uninitialized drive.
    • If you have multiple hard drives, make sure you select the correct one as the next step will wipe the selected drive clean.
    • Click the "Erase" button at the top of the window.
    • Choose a name for your drive (you can rename it later). Leave the scheme as GUID Partition Map.
    • If you are installing an SSD, choose the APFS format. If you are installing a mechanical drive or if your device doesn't officially support the newer OS, leave the format as Mac OS Extended (journaled)
    • Click "Erase." When the process completes, click "Done."
    • Exit the Disk Utility by clicking on the red X button on the top left corner of the window.
    FixBot'a Sor
    Yorum Ekle
  5. How to Install macOS High Sierra: adım 5, 2 resimden 1. How to Install macOS High Sierra: adım 5, 2 resimden 2.
    • Select "Reinstall macOS" from the menu and press [enter] or click "Continue."
    FixBot'a Sor
    Yorum Ekle
  6. How to Install macOS High Sierra: adım 6, 3 resimden 1. How to Install macOS High Sierra: adım 6, 3 resimden 2. How to Install macOS High Sierra: adım 6, 3 resimden 3.
    • Read through the license agreement.
    • Click "Agree" to accept the license agreement.
    • Your Mac will now install macOS High Sierra. Be patient and wait for it to complete.
    • Once the install is complete, the device will restart itself.
    FixBot'a Sor
    Yorum Ekle
Sonuç
High Sierra should now be freshly installed! Enjoy!
639 farklı kişi bu kılavuzu tamamladı.
Arthur Shi
338.301 İtibar
851 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
122 Üyeler
26.617 adet Kılavuz yazıldı
76Kılavuz Yorumları
I replace Toshiba MK1231Gal dard disk based on instruction on yutube http://www.youtube.com/watch?feature=pla...!
the problem is that when I try to install osx, I cant format the disk
I got notice input, output error, when try to make a partition or try anything with disk utility
I own MacBook air 1237
Iztok - Yanıt Paylaş
yes, me too...did you get it fix? please share how.
jay zee - Yanıt Paylaş
Use disk utilities from the Mac OS installer to format the new drive in a Mac format. Then install the Mac OS. New drive won’t show up in the installer until it’s Mac format.
littleduckltd - Yanıt Paylaş
DDD in this case
dard disk
Ben Capehart - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 84
Son 7 gün: 604
Son 30 gün: 2,488
Her zaman: 1,956,693
